It is currently Tue Aug 04, 2026 4:17 pm
 Post subject: Transducer Location
PostPosted: Mon Apr 13, 2015 7:19 am
Currently fitting a replacement sounder to a 2012 AI and interested to hear where people are fitting the transducer? I previously had it between the mast step and the mirage drive well, but curious to hear where other people fit theirs?
Nearer the rear of the hull for example.
 Post subject: Re: Transducer Location
PostPosted: Mon Apr 13, 2015 8:24 am
I started out with mine placed the same as yours. I had problems with loosing my depth reading when conditions became rough and that area of the boat was leaving contact with the water.
That was in a TI soloing from the rear seat. I moved the transducer to under the rear seat. I cut out a small piece of the flotation so it is covered and protected. I rarely loose depth since the move.
I realize my "problem" probably doesn't apply to an AI, but just wanted to point out that transducers seem to work fine mounted in the rear of a boat. I just made my maiden voyage with a Garmin DownVu unit this weekend and it works fine in that location as well.
PostPosted: Mon Apr 13, 2015 7:04 pm
Mione is mounted in thje rear scupper of my TI, using the Lowrance scupper mount kit. I am conscious that depth readings are from over 10 feet from the bow, but watch for shoaling depths so I don't damage the Miraedrive fins if approachng land.
PostPosted: Tue Apr 14, 2015 7:15 am
Thanks guys. Kind of confirmed my thinking. I was getting the saw tooth image of the bottom on the screen due to the bow getting a bit of air on waves. Plus I figured that if the transducer comes supplied with a transom mount, then...........
Looks like it will be going under the seat.
