It is currently Sat Apr 18, 2026 5:39 am
PostPosted: Fri Apr 17, 2015 2:16 pm
I am patiently waiting to hear back from Hobie the hull issue. The crack is under the seat where the plugs into the seat sockets. Has anyone had any experience with Hobie and this problem?
Thanks!
PostPosted: Sun Apr 19, 2015 11:14 am
Did you contact your dealer? File a claim? That would be the way to let our warranty and tech guys handle it. There is a fix kit for this problem.
PostPosted: Tue Apr 21, 2015 11:04 am
I don't understand where this crack is by the description. mmiller can you inform us what to look for?
PostPosted: Wed Apr 22, 2015 8:47 am
The crack would be in the 2014 or older model seat peg holes I assume. There are 4 per seat (2 pair). The crack shown in this image is not easily repaired. The kit would fix a crack down inside the hole. It is simply a kit with a plastic cap that gets glued over the area inside the hull.
