It is currently Mon Jun 08, 2026 7:47 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
PostPosted: Sun Apr 19, 2015 8:11 am
After sailing yesterday, noticed a couple potential issues with the rudder control lines as they exit the stern.
First, there's a grommet on the starboard line which I've not noticed before:
Any concern with this?
Second, the lines appear to be cutting into the plastic rings where they exit on both sides:
After three sails, I'm wondering if the wear will progress and would appreciate any insights.
Thanks for any help.
PostPosted: Sun Apr 19, 2015 11:24 am
That is odd. Why is the line exiting at such an angle? Maybe the lines are way to tight.
The O-Ring belongs inside the tube as a floating seal.
PostPosted: Tue Apr 21, 2015 8:55 am
Matt I have the exact same issue on the left rudder line. Mine is cutting a groove directly upward and appears to be through the bushing. The right is fine. I have had alot of issues with the rudder lines bu thought I had remedied them, I also have that oring on the line on the outside. I just pushed it back in.
PostPosted: Tue Apr 21, 2015 9:10 am
This is baffling me. When sailing... the lines extend aft, not up. Maybe this happened in transit when we had the rudder on the deck for storage / packaging? Our demo boat here is the same though.
PostPosted: Tue Apr 21, 2015 9:18 am
When the rudder is attached above for storage there is no tension. I think is because the rudder lines especially on the left side are being forced by other lines to one side or up or down when under tension from turning. I think this needs to be remedied quickly as it will soon be cutting into the hull.
PostPosted: Tue Apr 21, 2015 9:37 am
I'll take a look at mine. I've only had it out twice though. I'll take pictures if there is any wear.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Kayakbob's Sprayskirts
  • Spine Board Hakas
PostPosted: Tue Apr 21, 2015 10:28 am
PostPosted: Tue Apr 21, 2015 10:44 am
Sorry for the large images. I have had the boat out about 10 times.
PostPosted: Tue Apr 21, 2015 12:22 pm
Port steering line:
Starboard steering line:
Rudder up/down lines:
Port steering line deflection (minimal amount of pressure):
Starboard steering line deflection (minimal amount of pressure):
I included the deflection pictures to show that I don't believe the lines are overly tight. It looks like the majority of the wear is on the port side (both steering and up/down) with a little on the starboard. Like I said before, the boat has only been out twice for maybe a total of 3 hours on the water. The fact that I had rudder misalignment right off the bat and now this abnormal wear makes me a little concerned.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Spine Board Hakas
PostPosted: Tue Apr 21, 2015 12:39 pm
Mine is worse on port also. The tubes seem to be able to rotate somewhat so perhaps the direction of wear or tension isn't necessarily fixed.
PostPosted: Tue Apr 21, 2015 2:27 pm
Wondering if this is on all or just some of them. Not going to get to concerned until I get mine checked out and a few weeks of use. Will Hobie stand behind their product and make it right? This forum is a good place for them to get and give feedback. What's the fix Hobie?
Chris
2015 Tandem Island-ivory dune
PostPosted: Tue Apr 21, 2015 9:04 pm
My TI looks the same, and again is worst on the port side. I remember noticing they were this way when I unpacked it fresh off the truck so it's something to do with packaging / shipping.
PostPosted: Wed Apr 22, 2015 3:11 am
I remember reading on the issue of putting a cover on the TI that you had to lay the rudder flat to cover it, and when doing this the rudder lines cut into the fittings. Could this be what causes this? Is this how they are shipped?
I will be getting my TI soon I will take pictures of it out of the box.
PostPosted: Wed Apr 22, 2015 3:51 am
Matt, are you suggesting that the demo boat has this problem and has never been packed for shipping?
PostPosted: Wed Apr 22, 2015 8:25 am
I just took delivery last Friday on my T1 and it has not been in the water yet.
Looks like whatever is causing this was either from the factory or during shipping.
Port side
Starboard
I also noticed that the lines were pretty tight. Any guidelines on how tight they should be?
2015 Hobie Tandem Island
