It is currently Wed Aug 05, 2026 10:19 pm
PostPosted: Tue Apr 21, 2015 10:56 am
These came in the TI parts bag when I picked it up. Can someone tell me what these are used for?
2015 Hobie Tandem Island
PostPosted: Tue Apr 21, 2015 11:34 am
The two black things are scupper plugs and the line is to connect them together (at least that's what I did). The allen wrench is to tighten all the fittings on the boat. I also believe that in order to install the riser for the rudder handle it takes the allen wrench.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Kayakbob's Sprayskirts
  • Spine Board Hakas
PostPosted: Tue Apr 21, 2015 1:51 pm
I suspect that those scupper plugs have been made obsolete with the new seat drainage system
PostPosted: Tue Apr 21, 2015 1:54 pm
Thanks Tom, That makes sense.
I will be sure to put the allen wrench in a tool kit I am putting together to have on the TI.
I was also planning on putting the risers on the rudder handles. I will probably wait to use them, but the riser looks like it would be more comfortable.
thanks again!
PostPosted: Tue Apr 21, 2015 2:36 pm
There are two scuppers just ahead of the rear seat drive well. I use the scupper plugs in those. At higher speeds water tends to "spit" out of them if left open! :lol:
PostPosted: Tue Apr 21, 2015 3:35 pm
My dealer went ahead and just installed the risers. I didn't even ask him to do that, but I do find it comfortable with the new seat height. @RandomJoe, nobody told me that's what they were for but that's where I figured they belonged.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Spine Board Hakas
PostPosted: Wed Apr 22, 2015 8:34 am
Hopefully they used some loctite - those screws can easily back out if there wasn't any used.
Jacques Bernier
http://www.hobie.com/
PostPosted: Wed Apr 22, 2015 9:48 am
I'm going to go over all my screws tonight and add Loctite if it wasn't used.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Spine Board Hakas
