It is currently Thu Jun 25, 2026 8:33 pm
PostPosted: Sun Aug 02, 2015 1:30 pm
I came across a great deal on a Humminbird side scan fish finder and decided to try and figure out a way to make the transducer retractable and still remain in the Hobie transducer bay of my 2015 PA14. A friend had accomplished this on his PA, but I never got to see the details of his setup. I tossed around several mounting variations and found I was limited in what I want to do because of the lack of the parts locally and/or having to research online and hope they worked.
So I went to my local hardware, picked up 2 small springs and spent a few hours yesterday with a Dremel tool.
Using the existing Humminbird adapters, I removed the bottom alignment tabs. I also removed some of the material at the base of those plastic tracks to allow the transducer to drop as low as it could go. Since this is not a setup where you are locking the transducer "in place", I loosened up the nylon nut so that the assembly would slide up and down that plastic track smoothly.
Here's the finished unit prior to added the pull cord.
Here it is with the cord added.
Since I use 2 nylon pad eyes for my shock cord straps that hold any tackle boxes I use under the seat, I decided to use two of the screws to add 2 nylon guides for the robe to run through. I added one of the nylon "hooks" that I use for the tackle box straps at the front to hook the end of the cord on. Here's the completed assembly with the transducer deployed.
Here is the setup with the transducer retracted. Sorry for the grainy picture below the hull. There is not a lot of travel needed for the cord to pull the transducer up enough to be inside the assembly. I took the PA out on the lake and it worked like a charm! :mrgreen: Another benefit of having it spring loaded is that if you happen to hit anything, the transducer just pushes up into the well and then springs back down. It's not a fancy setup, but it works for me. Now to "cheat" as they say having a kayak with side scanning sonar. :D
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Pro Staff
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Sun Aug 02, 2015 6:37 pm
I love my Humminbird 768, but have "lusted for a side scan".....Your modification is really creative and slick too!
Thanks for the close up photos documenting your work.
Now I can save my pennies for a side scan fish finder, to install on my 2013 PA-14 and know there is a simple installation solution of the transducer, so it will work correctly....
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Mon Aug 03, 2015 11:34 am
Thanks for sharing!
The simplicity and design is brilliant!
Would love to hear how the SI performs on a kayak
There are some good videos on youtube which sparked my interest to install one on my PA12
https://www.youtube.com/watch?v=up1U5cgYkGI
https://www.youtube.com/watch?v=3kGfIjFnHFM
PostPosted: Tue Aug 04, 2015 6:46 pm
I like it, but why and when do you need to retract it? I've had my SI transducer mounted slightly proud of the housing for 2 years now with no problems at all. (I launch on sandy beaches 99.9% of the time.)
Cheers,
Graeme
PostPosted: Tue Aug 04, 2015 7:33 pm
Cheers,
Graeme
I don't launch on sandy beaches. While the middle hull area does not usually rub where the transducer is, it is very close to the ground when deployed. Having it retracted in the housing keeps it from being scrapped on a hard uneven surface. Granted I don't drag the hull over any hard surfaces to reduce scratches...lol. Time will tell if I change it up. Happy so far! :mrgreen: Tight lines!
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Wed Aug 05, 2015 2:46 pm
You beat me to the punch on this one, I was working out how to make the transducer return back below the hull. I was thinking about some sponge or a piece of pool noodle wedged above the transducer that would allow the transducer to float up in the event of compression and still push the transducer back down after. I had completely overlooked using springs. Any chance you'd mind sharing how long those springs you used are?
As for my PA17, the Kayak cart with Beach Wheel supports the boat right where they put the Lowrance Ready mount, so having a transducer below that area would interfere with the Kayak cart supporting the boat properly and put extra strain on the transducer adapter arms without them being spring loaded.
PostPosted: Wed Aug 05, 2015 4:54 pm
The springs I used were from Lowes. Hillman #22 Compression springs. Item #422422. Size 3/8 X 1 15/32 X .035. Cost $2.47 for the package of 2 springs.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
