It is currently Tue Aug 04, 2026 10:39 am
Post new topic Reply to topic  [ 79 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Thu Aug 06, 2015 9:01 am
Well.....I contacted my dealer. Used blue grease to identify the areas of the hatch that did not make contact. It only makes contact at about 25% of the circumference. Took it to the dealer for them to see. Sent pics, etc. Im told that Hobie is saying," too bad , that's the way they are, they are not made to be water proof." Not acceptable.
PostPosted: Thu Aug 06, 2015 9:12 am
Not what we would be saying. This is fixable... The flange can be trimmed and the hold down straps are adjustable.
PostPosted: Thu Aug 06, 2015 9:49 am
would you like me to forward the email from my dealer?
PostPosted: Thu Aug 06, 2015 10:07 am
Yes, please do... that is not the appropriate answer.
PostPosted: Sun Aug 23, 2015 6:47 am
Hi there,
I'm from Melbourne, Australia and recently purchased a 2015 Outback.
After reading this thread I'm a little concerned, has Hobie identified this and is there a fix?
I just want to know before I contact my dealer about it. I'd like to know that in the event I of a potential capsize there would be very minimal to no water intake into the hull.
Cheers
PostPosted: Mon Aug 24, 2015 11:30 am
Im told they are looking into it...not all have the issue. You can grease the top of the rubber seal and close the lid to see where yours makes contact. You can also roll it over in the water and wait about one minute to see how much gets in if any.
PostPosted: Wed Aug 26, 2015 4:51 pm
The trimlock from the Pro Anglers might help - this is a thicker taller seal, you can try getting some of that seal (part # 71305001) we've tested this on Outbacks here and it seems to work better. Engineers are working to come up with a better trim package and working with our vendors who sell the trimlock materials. So far we don't have the complete solution, but if you'd like to give the Pro Angler part a try it's pretty simple to do so.
Jacques Bernier
http://www.hobie.com/
PostPosted: Thu Aug 27, 2015 10:45 am
from a previous post in this thread
"It seems simple to solve to me...if the seal were made taller it would then seal against the plastic lid...but that would not work for the bucket when installed...it would need a lip for the bucket to tuck into so that it would leave rubber above it to seal to the lid....or, the seal could be made wider so that it seals against the outer edge of the plastic lid where it rolls over...seems sooo easy, wonder why they have not done it??"
sealing against the outer edge would solve all the issues as far as I can tell, to include the bucket not sealing that Hobie sells for this model.
PostPosted: Thu Aug 27, 2015 10:47 am
Jbernier, can you send me this Trimlock as part of a warranty fix?
PostPosted: Thu Aug 27, 2015 10:49 am
We are pressing engineering on this issue. They have tried larger seals in the past, but fit was an issue. Larger... did not fit and prevented some hatches from sealing. This may have been on other models like the Adventure Island, so we are asking them to look again at all models.
In the factory they have fixed some trim tooling and further trained assembly staff...
PostPosted: Thu Aug 27, 2015 2:52 pm
Contact your dealer and have them get it for you directly - it's just 5ft of trimlock from a PA. (part # info provided in my previous post)
Jacques Bernier
PostPosted: Thu Aug 27, 2015 6:12 pm
thx
PostPosted: Thu Aug 27, 2015 7:34 pm
Thanks for looking into this.. I have a liner as well and launch through big surf and always have water in the liner after I clear the zone. Didn't happen on my older outback.. I deal with Andy at OEX who is excellent and will have him contact you guys about a fix along with another issue I'm having.
PostPosted: Fri Aug 28, 2015 9:19 am
There isn't a way to keep water from getting into the hatch liner - this is only related to sealing the hatch without liners - once you add a liner it can take some water the way you've described since there's no seal above the liner between the hatch - that's not something we're looking into at the moment.
Jacques Bernier
PostPosted: Fri Aug 28, 2015 9:23 am
That's odd, so in order for me to keep water from getting inside the kayak I should not use the hatch liner made for the outback? And there is no solution for this other than not using the liner?
Just want to make sure understanding you correctly.
