It is currently Thu Jun 11, 2026 7:13 pm
 Post subject: Weight
PostPosted: Sat Sep 26, 2015 6:40 am
Should the heavier of 2 people sit in back or front or does it make no difference?
Alan
 Post subject: Re: Weight
PostPosted: Sat Sep 26, 2015 10:53 am
This is the same for all boats / ships...
Best with heavier weight in the rear for better steering and tracking control. Weight forward can cause a hull to turn. This makes steering more difficult. In addition, weight forward raises the rudder and reduces steering surface in the water and reduces control further.
PostPosted: Sat Sep 26, 2015 11:01 am
I would mention though that if the weight differential is great enough you can cause the bow to ride higher than normal. This causes issue with tracking as the wind can blow the bow all over the place.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Kayakbob's Sprayskirts
  • Spine Board Hakas
