It is currently Sat Jun 06, 2026 3:51 pm
PostPosted: Wed Mar 02, 2016 7:44 am
All,
I went out on Leap Day (Feb 29th) and spent my bonus day sailing all day. Lake Lanier had 8-10mph winds, gusting to 22.
Wowzers, I love this boat! I learned an important lesson about leash it or loose it. I had a really old GPS that I used on my bike made that terrible "kerplunk" sound as it went overboard.
That being said.. What are you using and recommend for GPS?
I am trying to decide on a handheld vs small fishfinder\GPS combo unit.
So what are the pros and cons from those of you that have used both or have a preference either way?
BTW I am leaning towards a floating handled, but with the prices overlapping with the entry level combo units with GPS and fishfinder I am a bit torn. I understand that a mounted combo unit adds additional complexity and a need for another battery, wiring etc.. I fish casually, want tracking ability on my local lakes, want basic GPS functions to show current, avg speed etc, but also want trip planning and navigation for when I am in places other than my local lakes (SW Florida in particular)
Paul Links
PostPosted: Wed Mar 02, 2016 10:14 am
I use Garmin handhelds mounted with RAM ball mounts just in reach on the gunnels. GPSMAP 76 shown below and I now have a new GPSMAP 78, 3 models to choose from, depending of features needed. (my fish finder also shown mounted on the right)
PostPosted: Wed Mar 02, 2016 11:08 am
KB, 1+
PostPosted: Wed Mar 02, 2016 11:52 am
I'm using a Lowrance HDS 7 with Navionics. Though I also carry a Garmin 60Csx loaded with Bluecharts for backup.
ImageP4150451 by Rob Appleby-Goudberg, on Flickr
Follow my blog @ Saltwater Kayak Fisherman
Watch my videos on You Tube
Team Hobie GB
Lowrance Pro Staff
YakAttack Pro Staff
Hook1 Crew
PostPosted: Wed Mar 02, 2016 4:19 pm
I use a Garmin Dakota 20 with local maps of Sardinia (very accurate 1:25000 scale) that i uploaded in the memory. I dont have bathymetry anyway but ... do i need?
After having thought about fixing it somewhere in the cockpit i decided to keep it in my pocket and check it when i need. consider that I dont fish much. the fuctions i need are speed and distances from the waypoints
PostPosted: Wed Mar 02, 2016 8:16 pm
garmin 78sc here, love it the unit but I am quite disappointed in the "waterproof". after taking several good waves it will pop up and say "lost external power" and it begins a countdown to shut it off. I am now looking for a dry bag for it. kind of defeats the purpose of a waterproof floating gps doesn't it?? also, it seems this is not a rare problem (hence the reason I am just accepting it as it is). seriously though, the gps is really nice if you can get past the fact you would have to keep it in a clear dry bag...
2015 Outback- dune with sail kit
2015 TI- dune- sold
2015 AI2- Hibiscus- should probably sell...
2018 AI2- Dune
PostPosted: Wed Mar 02, 2016 8:26 pm
My Lowrance elite 5 has been reliable and it has endured some spray... Here I am catching a swell and it crested right at my aka bar.. The Lowrance keeps on going... However, I have always had the microsd card slot taped shut with clear packaging tape. That is good insurance.
PostPosted: Wed Mar 02, 2016 8:43 pm
I fill unused ports with silicon adhesive and used ports with Di-electric grease to keep the salt water out. My first 76sc died the first week without it.
No problems for 5 years since filling all ports under the flimsy flaps.
PostPosted: Thu Mar 03, 2016 1:38 pm
Thanks everyone.
How long does the Elite 5 run on a small 12v battery?
Paul Links
PostPosted: Thu Mar 03, 2016 7:31 pm
Aero_70 wrote:
Thanks everyone.
Paul Links
When I turn my screen brightness down to 6-7 I can usually get around 12 hours using a Lowrance 5 Chirp
PostPosted: Thu Mar 03, 2016 11:15 pm
Aero_70 wrote:
Thanks everyone.
Paul Links
I am not sure... I bought the hobie kit with the battery and it fits into the back hatch in the TI. I charge it every time I go out and it last the whole day. You probably could run it down to 10.5 volts in about 12 hours or so, but, I have never tested it...
PostPosted: Sat Mar 05, 2016 4:14 pm
My lowrance gets the famous "fogging on inside of screen" sometimes from moisture inside. Everybody blames the microsd card slot for allowing water ingress and perhaps thats true - but mines not a GPS unit, so mine has no microsd card slot at all its just "solid plastic" there - yet still got moisture inside within a month of ownership lols (and my sounder was mounted in the center of my old yak between my feet - where it got *zero* salt water spray - the light hosing off after a day out is where mine got moisure in it lols)
Obviously in my case it cant of gotten in through the microsd slot as there isnt one - but mine does have a small rubber bung on the back of the unit under the wiring plugs - which is the only possible point of entry on mine (unless factory stuffed their seals)
Check for a rubber bung on lowrance units - if it exists - Glue this down with sealant too (the bung just presses on and off)
If you already got moisture inside - remove that bung and sit unit in the sun "screen down" to allow for evaporation out that hole - then glue the bung back in lols (no more foggy screens for me)
To work out battery life - just check specs for the sounders power draw. If the sounder draws 1amp - then thats 1amp per hour of use. Means a 7amp hour battery theoretically lasts 7 hours? (my understanding of it anyway) I get 8 hours no worrys from my 7amp hour and my lowrance elite4xhdi - but I dont have GPS and perhaps that chews more power no idea?
PostPosted: Sun Mar 06, 2016 8:09 am
When you see fogging/droplets in the window on a gps, the end is not far away.
PostPosted: Mon Mar 07, 2016 8:28 am
Lowrance has an excellent warranty. Maybe send to them and they will probably send you a new one. They have for everyone else I know that's ever had any issues.
