It is currently Sun Jun 14, 2026 10:11 am
PostPosted: Fri Jul 15, 2016 3:06 pm
Has anyone had issue with cracks on both ends at the top of aluminum Xbar, (where aka slide and locks into). Does Hobie consider this as normal wear?
Two cracks (it actually split about 2 inches long on upper Xbar on left side, I removed right side rubber edge guard and notice 2 -1" cracks on right side.
Sailing upper chesapeake
RedRobin
PostPosted: Fri Jul 15, 2016 4:18 pm
Should not happen... see your dealer.
PostPosted: Fri Jul 15, 2016 7:45 pm
High risk issue. Definitely a dealer issue. Agree with Tony.
Greg
2016 AI - Spinn & Jib
– Charles G. Davis
PostPosted: Sat Jul 16, 2016 11:10 am
Hi Guys,
Well I just checked my 2015 AI and the same thing, only one crack on right side.
Have to remove rubber cover to see cracks.
Anyone interested in photos you can go to, https://drive.google.com/folderview?id= ... sp=sharing
Hobie 2010 AI
Hobie 2013 TI
Hobie 2015 AI
RedRobin
PostPosted: Sat Jul 16, 2016 11:34 am
Jesus! Now I'm going to go check mine. I have noticed some extra play recently.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Kayakbob's Sprayskirts
  • Spine Board Hakas
PostPosted: Sat Jul 16, 2016 12:29 pm
Can you guys share how to remove and reinstall the rubber. I'd like to do the same when I'm close to 2 years. Right now I can only notice slight play in that area in which I think is normal.
PostPosted: Sun Jul 17, 2016 10:20 am
Will check mine for sure. Who would have thought.
Greg
– Charles G. Davis
PostPosted: Fri Jul 22, 2016 11:35 am
Just received message from my Hobie dealer, Hobie sending out replacement for both the TI and AI.
PostPosted: Sun Jul 24, 2016 6:10 pm
Checked mine out today. No cracks.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Spine Board Hakas
PostPosted: Thu Sep 15, 2016 4:58 pm
Yes, 2 out of 4 of mine are cracked, new ones are on order! To replace them, the X-bar (Crossbar) must be removed to take the bottom very short screw off, then re-assemble! To me, it is normal wear item?
2005 AI Blue hull (yep, only one ever made!) Prototype!
2014 TI Red hull
2002 MacGregor 26X PowerSailor 50 HP on the transom!!!
PostPosted: Wed Apr 05, 2017 10:01 pm
I had the exact same problem in my 2013. It cracked and released mid-sail.
I had asked my the dealer (Maclean NSW who are great) to follow up with Hobie who said they would not cover it under warranty but that I could post the old Xbar in (presumably at my expense) to be assessed. I will now do that as this appears to be a relatively common occurrence.
Can anyone tell me of theirs was covered under warranty?
Many thanks
PostPosted: Thu Nov 07, 2019 3:49 am
My front Xbar on my 2013 also cracked two years ago. After some to and fro and me pointing out several US blogs hobie agreed to replace as ‘good will gesture’. Two weeks ago my rear has gone. This new system just does not seem to be designed as well as the old pin style. We have some that must be 15 year old. Never needed replacing.
Agree with the above - McLean Hobie are fantastic to deal with and good prices.
