It is currently Mon Jun 15, 2026 10:49 pm
 Post subject: Tiller Crossbar
PostPosted: Wed Jul 27, 2016 6:58 am
I'm new to this forum.....I just brought a old Hobie 14 Turbo, and was working on the rudders.
The tiller crossbar rudder adjusters were lose, is there a measurement that they should be set at?
Also the plastic adj screw for the rudder up-down locks that has the slot for the screw driver has been damage ......how could I get the damage plastic screw out now?
 Post subject: Re: Tiller Crossbar
PostPosted: Fri Jul 29, 2016 10:26 pm
I thought an expert would chime in by now. as for the plastic adjustment screw, you may end up drilling it out. I believe I've seen a thread about that.
As for adjusting the tiller connector, you want the leading edge off the rudder and trailing edge to be about the same. That's were you would take your measurements at.
Make sure you have the rudders on the correct sides before you start.
There is a good you tube video on rudder adjustments.
JKK
83 yellow/ white decks Hobie 14 Corando turbo
82 yellow hulls Hobie 16 Cat Fever
84 yellow hulls hobie 16 Yellow Nationals
plus a few extras that I'm restoring
PostPosted: Mon Aug 01, 2016 10:31 am
Rudder FAQ: http://www.hobiecat.com/forums/viewtopic.php?f=18&t=467
FAQ link: http://www.hobiecat.com/forums/viewforum.php?f=18
PostPosted: Mon Aug 15, 2016 2:36 pm
I like to thank you for your reply
Plastic adj screw for the rudder up-down lock ......i solved this problem by heating up a wide screw driver blade and slowing melting a new slot for the screw driver.
