It is currently Tue Aug 04, 2026 12:00 pm
Post new topic Reply to topic  [ 318 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 22  Next
PostPosted: Wed Mar 01, 2017 2:12 pm
I think Bixpy will start shipping the first batch this month. I'm excited to hear the review from Hobie owners.
I'll wait for a couple of Hobie owners to share their reviews before I place my order.
Good to know there will be two players (Tor and Bix) to choose from. Always good for consumers when there's a competition.
PostPosted: Wed Mar 01, 2017 2:22 pm
There is now a look-alike Torqeedo competitor as well from China: http://www.epropulsion.com/index.html
Basically double the size batteries for the same price of particular Torqeedo models.
PostPosted: Thu Mar 02, 2017 6:45 pm
I am looking at different possibilities for a solar setup and seeking expertise from anyone who can provide it. My understanding is that exceeding 4 amps on the 915 Wh batteries will blow an internal fuse (requiring service of the battery back at the repair center), making a 100W panel that runs above 4A unacceptable. Does anyone know if wiring two 50 W panels in series such as the ALLPOWERS 50W 18V 12V Solar Panel from Amazon would work better? I have also considered the, '75W 36V Flexible Folding Solar Panel Charger Light weight Portable for Torqeedo,' available from eBay but there are not many reviews. The 36V supposedly charges the battery faster because a full 915Wh battery lies at a resting voltage of 33.6V. I'd love to hear people's opinions on these different options.
PostPosted: Fri Mar 03, 2017 7:07 am
I think you may be confusing charging the battery with drawing current from the battery. If you were to short out or otherwise draw too much current from the Torqeedo battery it would indeed blow its internal fuse when the current drawn exceeded what is considered safe. This should never happen in normal use.
However when you charge the battery the newer (post 2015) Torqeedo batteries internally limit the charge current. The specs say you can charge them with any DC source from 9.5 to 50 VDC.
Four amps is the minimum current that needs to be available from the charging source, not the maximum, and this is only because if you charge the battery with anything less it may charge too slowly and the battery's sleep mode may engage before the battery is fully charged.
So you could even take a 12 VDC car battery which can supply massive amounts of current for a short time and safely directly connect it to the newer Torqeedo batteries and the charge current will be internally limited to around four amps.
Again, you can use any 9.5 to 50 VDC charging source that is capable of providing at least 4 amps. The higher the voltage the faster the battery should charge because with a constant charging current of 4 amps a higher voltage will provide more usable charging power (P=I*E). It looks like charging sources supplying 38 Watts (4A * 9.5V) to 200 Watts (4A * 50V) are acceptable. Anything less than 38 Watts won't charge the battery fast enough and anything more than 200 Watts won't make it charge any faster. There's more to it than this of course but this is a good basic reference point.
PostPosted: Fri Mar 03, 2017 7:51 am
So by the sound of it all the charging control is within the battery itself verses a complex charge controller.
So in other words most lithium stuff that I've seen is very smart charge controllers (for safety reasons) and dumb batteries.
If I understand correctly what you are stating these batteries have their own charge controllers built in (very smart and safe batteries), and it appears can be charged with any old dumb charging source as long as it's above a minimum current (4amps), and appears the higher voltage you supply the faster the unit charges, apparently without fear of fire and explosion (ie... Samsung S7, or Boing dreamliner stuff).
This simplifies my own proposed system tremendously as I was planning to use a completely separate 12 volt system (cheaper), passing thru a small 110vac inverter, powering the standard torqeedo 110vac charges (because I thought they were smart chargers).
This changes and simplifies my plans dramatically, By the sounds of it I can eliminate the inverters completely now, and come up with a new concept alltogether.
I'll still need 8 batteries and twin Torqeedo 403's to accomplish my goals but charging them will now be much easier.
Interesting
FE
PostPosted: Fri Mar 03, 2017 8:01 am
Interesting
FE
Correct, in the case of the newer post 2015 models (with the onboard USB socket), the Torqeedo batteries are "smart" so the chargers can be "dumb". This makes life a lot easier for end users who can now safely charge these batteries with almost any simple DC power source in the range of 9.5 to 50 VDC at 4 amps without worrying about elaborate charging circuits.
Torqeedo batteries are expensive but you get excellent electronics with them including the charging circuits and a GPS.
PostPosted: Fri Mar 03, 2017 12:45 pm
I have my fishfinder battery plugged into the torqeedo which extends its range. The torqeedo battery will take a charge from any 12v battery at a rate of approx 36watts until it is full. It Will also cut off charge automatically at around 11.2 volts which will prevent your ff battery from over discharging.(your ff may take it all the rest of the way down ).If you have a ff battery, might as well connect them. You will then ONLY ever have to charge your FF battery with a single battery tender. Keep in mind the most range you can gain this way is limited.Even the biggest battery over an average 10 hour day will only give you an extra 360Wh.
PostPosted: Fri Mar 03, 2017 2:02 pm
Thanks everyone for your guidance! I will try two 100W 12V-18V solar panels hooked in series.
PostPosted: Mon Apr 17, 2017 6:45 am
Update:
The new Torqeedo 1417-00 915 Watt Hour battery specifically made for the 403 Ultralight motor is now available for $787 here. This is the lowest price I've seen for any Torqeedo 915 Watt Hour battery and the lowest price for capacity per dollar.
This battery has almost three times the capacity of the standard 1416-00 403 battery which sells for $525 and almost twice the capacity of the compatible 1147-00 battery which sells for $612.
Prices are current as of the date of this posting and are subject to change.
PostPosted: Thu May 18, 2017 5:31 am
In my review of the 403 I mentioned that ideally the prop could be a few inches deeper into the water than the maximum mounting adjustments allow. This would help with a couple of issues:
    - Reduce or eliminate cavitation at max rpms for even greater speeds
    - Help prevent the prop from coming out of the water in turbulent conditions
I asked Torqeedo if a longer prop shaft was available. They replied no. So I originally thought of replacing the prop shaft myself. This presented a few significant problems: it probably would have voided the warranty, and the wiring going to the motor would probably need to be extended which would have been difficult. So I abandoned this idea.
Over the winter I thought of several ways to lower the motor a few inches but I didn't like any of them because they were either too difficult or too kludgy or both. Finally it dawned on me how to do it. Using a couple of parts available from Torqeedo shown below, I could simply cut the existing horizontal shaft as close as possible to where it mounts to the vertical shaft, mount a Clamp Base to each cut end, and then attach an easily fabricated aluminum plate of whatever length I desired between them to lower the prop as much as I wanted. Unlike the prop shaft which contains wiring, the horizontal shaft is just a simple 44mm (1.75") aluminum tube. You could either purchase another horizontal shaft directly from Torqeedo for $23 or buy your own aluminum tube if you didn't want to cut the original.
Clamp Base UL Item number 069-00015
Fortunately Torqeedo sells the Clamp base right on their web site right here so I ordered the parts yesterday. When they arrive I'll fabricate the plate out of a piece of aluminum and mount the motor. If this proves successful I'll post the results here.
This may take me a few weeks to do since I'm also very busy at work and with other projects. So I wanted to offer a preview of this now since boating season in the US North is getting underway. Anyone else who may wish to take it upon themselves to try this (at your own risk) might not want to wait until I'm finished. I'm reasonably sure that it'll work but I can't say for certain until I rig it up and test it.
So stay tuned and I'll let you know what happens along with photos if successful. I think this relatively easy modification will reduce or eliminate cavitation that occurs at the highest rpms which may result in even greater speeds, so it's worth a try.
I should note that this is only a performance modification to try and get a bit more speed. The 403 works nearly perfectly out of the box on the TI and this modification is not necessary for normal operation. But I'm a tinkerer and enjoy this kind of thing. If you're the same way you'll understand. It's my goal to make the 403/TI application as optimal as possible.
PostPosted: Thu May 18, 2017 10:50 am
My setup is a PVC one that you plug into the fishing rod holders and tether down using the boat's bungie cords. My Ultralight 403 sits very deep in the water because I used PVC to extend the shaft downwards. I then have the original metal shaft secured inside the PVC so that I retain the ability to tilt the motor using strings. The good news is cavitation is greatly reduced, but I have never seen any speed or range improvement unfortunately. However, my 200W solar panel (thanks to your suggestions pro10is) has been a great success in extending the range in off-shore, remote locations without any place to plug-in or re-fuel.
PostPosted: Thu May 25, 2017 7:51 pm
Very interested in your findings. I would love to get rid of the full throttle gurgle myself.
PostPosted: Thu May 25, 2017 8:07 pm
Also, if you don't mind me asking, when you utilized the Yakima Windjammer, where did you position it on the motor shaft?
Down against the motor, or in the middle of the shaft, or toward the waterline?
Dave
PostPosted: Tue May 30, 2017 7:01 am
Over the weekend I had the opportunity to work on a bracket to lower the Torqeedo prop on my TI. The bracket is very simple, it uses a component from the Torqeedo motor itself called the "Clamp Base" (Item number 069-00015). You can purchase this component right from the Torqeedo site (see post above). Since it's already an existing Torqeedo part for this motor, there is no concern about its qualifications for the job.
I mounted two of these units onto a 3" wide by 6" long by 1/4" thick aluminum plate as shown below:
The plate was easily fabricated from a scrap piece of aluminum. Since aluminum is relatively soft, it's easy to cut and drill. You could also use stainless steel but it would be a bit harder to fabricate unless you have the right tools.
The length can be any dimension you wish depending upon how far you want the prop in the water. Six inches seemed to be a good dimension to try out first. You can then make any fine adjustments by using the existing Torqeedo prop depth adjustment which before had to be set to the maximum depth.
Next I cut the existing aluminum horizontal shaft in such a way as to allow one clamp base to be mounted very close to the existing prop shaft mount. Then I simply mounted the clamp bases to the cut ends of the horizontal shaft as shown below:
You can now see how this bracket will lower the prop depth. This setup is very sturdy and should have no issues in operation. When I get a chance I will next mount it to the boat using the existing ball mount. I might need to tweak it a bit to account for the steering lines going from the motor to the rudder. Also as before, the rudder will need to be moved to one side before it can be raised, but this never caused any issues in actual operation.
This should fix the only mounting issue I had with the Torqeedo motor installed onto a TI and allow whatever prop depth I want, but again this is purely optional as it is not required for operation.
PostPosted: Tue May 30, 2017 7:24 am
Dave
I positioned it against the motor. This seemed to make the most sense, but I need to experiment more to find the optimal mount.
