It is currently Mon Aug 17, 2026 9:08 pm
PostPosted: Fri Apr 21, 2017 3:16 am
Can you feather the blades so the eclipse can travel in shallow water without hitting bottom like you can do on a Hobie kayak? If not, what minimal depth of water is required for the Eclipse?
PostPosted: Fri Apr 21, 2017 8:59 am
Yes, you can use short shallow strokes in shallow water. Same as the std MirageDrive in a Kayak. The Eclipse does not come up flat against the board, so maybe 4-6" of water required.
