It is currently Sat Aug 22, 2026 12:48 pm
PostPosted: Wed May 24, 2017 7:13 am
Hi. I have an early model of Hobie Island and I am very pleased :-) But it has become a little oval gap in the connection between aka and crossbar where you insert the stainless steel pin. Has anyone found a solution to this?
PostPosted: Wed May 24, 2017 9:27 am
Going to need a picture to understand what is happening.
Greg
2016 AI - Spinn & Jib
– Charles G. Davis
PostPosted: Wed May 24, 2017 9:28 am
It's normal wear on older boats. Fill the hole with JBWeld and redrill it.
In rough, wavy conditions, these SS pins can "walk" out of loose holes. If you see this happening, use a small loop of bungee around the pin to hold it down after it's inserted.
The Wind Is Your Friend...
PostPosted: Wed May 24, 2017 10:08 am
We have found that gluing a small piece of cheap indoor/outdoor carpet on the flat end of the aka xbars fills and cushions the looseness, stopping the rattle and the wear seems to stop.Image
There are a few old posts about this like: https://www.hobie.com/forums/viewtopic.php?f=75&t=13167&p=75628&hilit=rubber#p75628
PostPosted: Fri May 26, 2017 12:34 am
Thank you for the answers :) I will try one of the solutions.
