It is currently Fri Aug 07, 2026 6:50 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Feb 18, 2009 2:41 am
Chekika wrote:
Geez--Bob, that is some setup. I know there has been talk about coming out with a tandem AI, but I think you need to seriously talk to Hobie about coming out with a larger, solo AI to accomodate your WaterWorld-like accessories.
That is an impressive setup, Bob.
Nah, we need a kayak-trailer. A floating trailer you tow off the back for all the stuff.
Geoff.
PostPosted: Wed Feb 18, 2009 9:53 am
Geoff,
You're not the first to suggest that! :lol: :lol:
Got to be prepared.
Kayaking Bob
PostPosted: Wed Feb 18, 2009 1:36 pm
At Last! The answer to my question "Why a bow line?". It's so you can take it off and tie it to the stern to tow all your gear. :lol:
 Post subject: Re: Why a bow line?
PostPosted: Sat Jul 28, 2018 6:22 am
I have used a bowline on my kayak since day 1. I use it all the time. Even on land. I pull it around on the ground, tie it when I am floating, throw it to shore to have someone pull me in. I dont see why other do not use it.
PostPosted: Sun Jul 29, 2018 5:15 am
I have set up a permanent 30 foot line tied to the front crossmember, and passing through a bow fitting. I can then, apart from the usual tethering to an object onshore, add additional line and/or chain, plus (bottom or sea) anchor, with a few shackles. As the line is passing through the bow, my TI lies very nicely on the anchor due to the pull being directly from the bow.
However, I also added a separate retrieval line as per the diagram, so I can pull the anchor line back info the cockpit without needing to reach the bow.
PostPosted: Mon Jul 30, 2018 2:44 am
that's pretty slick tony.
