It is currently Sat Jun 13, 2026 9:23 am
PostPosted: Fri Aug 10, 2018 12:15 pm
Ok so I finally had time to go thru and tune up my TI on the list
- clean/wipe down
- check all lines and fittings
- clean out all the extra stuff that gets lost in the hull (must have been like 20 little sand shoves and buckets)
- Hobie upgrades for aka/furling drum
- lube mirage drive
What other stuff do you do?
Findings and questions:
- furling guide was an easy fix and I only dropped one nut in the mast base. How do you get all the water out of the mast base? I use a sponge but is there an easier way?
- aka mounts - so my TI is a 17 and I think mine already had the upgrade...
New one on the left old on the right, so I stopped and didn’t change them. Question: if the aka brace shear pin breaks w/tramps on will the side collapse? Never really thought of it.
- mast - for those who had the rivets dig into there mast electrical tape worked for me
After one year (almost exactly) of sailing, probably 20-30 trips and no issues. Looked like this when I wrapped it.
-seat area - lastly anyone know what the brass inserts inset the seat is for?
PostPosted: Fri Aug 10, 2018 1:02 pm
Good idea with the electrical tape. I might just do that one. If you have tramps installed and the aka sheer bolt breaks the tramps will keep the amas from folding in...to a point. You could probably force it but it wouldn't be an immediate collapse. Heck I've sailed with one of the akas not even inserted correctly and the tramps kept the aka from migrating out too far until I could get it seated. The brass inserts are just for the molding process. It allowed the plastic to build up a little bit more in that area.
Sent from my SM-G950U using Tapatalk
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Kayakbob's Sprayskirts
  • Spine Board Hakas
PostPosted: Fri Aug 10, 2018 2:56 pm
In 8 years of TI sailing I’ve never broken a brace shear pin with the tramps on. Before the TI, I had two pin breaks on my AI’s but only when the tramps weren’t on.
I remember Roadrunners review, when the tramps first became available, where he deliberately hit objects with both braces disconnected and the tramps didn’t collapse:
https://www.hobie.com/au/en/forums/view ... 69&t=12342
If you hit something hard enough though, the tramp buckles may break, as reported by FE Bob.
With the aka upgrade check inside the Xbar to see if the upgraded springs are visible.
An alternative to insulation tape on the mast (I hate how the adhesive breaks down over time) is SOS self fusing silicon tape.
PostPosted: Fri Aug 10, 2018 4:59 pm
Stringy:
My tramp straps broke when my aka nylon sheer bolt broke, ( hit a wave wrong while going pretty fast) and I was on the tramp at the time and went in the water, fortunately I was able to hang on to the aka bar, (lol so I didn’t die).
However that was with the original smaller tramp clips, which were too weak. I’m highly confident the newer, (much stronger) wide tramp clips would survive just fine.
However I still recommend using the simple safety lines, just in case.
FE
PostPosted: Fri Aug 10, 2018 8:24 pm
Got it, thanks Bob. My tramps only have the smaller buckles but I haven’t had any breakages.
