It is currently Mon Aug 17, 2026 11:53 pm
PostPosted: Wed Oct 03, 2018 7:59 am
Hi all, I offered to help a friend repair his Mirage Kayak. The steering cable is broken at the rudder (both ends are still visible) and he needs some other parts. My problem is that this Mirage just says "Mirage" on it. I can't find any model that matches it - I'm assuming that it's an older model that may have been put out of production (?). Anyway, it is 12' 6" long (hull length). has a storage with the lid behind the seat and two hatches. I need to find the cable kit and the mechanism that secures the peddles (or the plug) - 2 X 3/8 threaded fem. Anyone with information that could steer me the right direction would be greatly appreciated.
>>>--->vwhead77
PostPosted: Wed Oct 03, 2018 8:51 pm
The Hobie Mirage was their original pedaling kayak, first produced in 1998. When other models were introduced, it was renamed Mirage "Classic". It was produced through the 2006 model year. Excellent little boat!
Your serial # should be on the side or bottom of the hull near the stern, hand etched. The last two digits are the model year.
If you want to send a pic of your drivewell, I'll be happy to see if anything is missing.
Your original rudder lines were monofilament, but have long since been replaced with Spectra. You'll have to re-string it yourself. 8)
PostPosted: Wed Oct 03, 2018 9:17 pm
Looking through an old parts catalog, I found a steering line replacement kit, Mirage -- part # 80016. It may or may not be available.
If you are missing the cam lock knobs, and bolts that secure the Drive, they are part # 81410 and # 8040531 They look like this:
Image 8)
PostPosted: Thu Oct 04, 2018 9:02 am
Thank you. I did manage to 'rig' the rudder cable using blue 'weed-whacker' line - seems to be holding up pretty good. Anyway, thank you for parts number for drive hardware. I will see if I can get my hands on those. Thanks again!!
PostPosted: Fri Jun 14, 2024 4:38 pm
We have a really old one too and are very much struggling to find replacement parts! Specifically an uptown handle rudder. We searched for the model number as everyone suggests online and there just isn’t anything anywhere with any numbers on the bottom of the boat.
PostPosted: Sat Jun 15, 2024 11:06 am
I have an old mirage with the same issue, broken up/down and steering handles which are impossible to find.
I think the reason Hobie changed the handle system is because the plastic just couldn't handle the stress from the set screw and would tend to crack, so even if you got a replacement plastic handle it would eventually suffer the same fate.
I've ordered a couple of these: https://www.ebay.com/itm/186438838697 and I'm hoping that I can fabricate new handles with a little bit of work, I'll let you know how it goes.
PostPosted: Sat Jun 15, 2024 3:35 pm
Thanks for the tip! We are going to give that one a try!
PostPosted: Sat May 03, 2025 9:16 am
Does anyone have the old PDF with all the parts for the oldest model Mirage by any chance? It's gone from the internet, this year.
