It is currently Fri Aug 07, 2026 11:56 am
PostPosted: Mon Oct 08, 2018 3:56 am
Anyone know if its possible to order the front H Rails of the 2019 Outback?
Looks like they’d be a perfect fit to add on to the back deck.
PostPosted: Tue Oct 09, 2018 11:08 am
There should be a parts guide coming soon. Normally we do not sell new parts as accessories for 6-12 months. New boat production gets all the stock.
PostPosted: Wed Oct 10, 2018 1:32 pm
Do you know if the front rails can be fitted to the rear as suggested by the OP?
PostPosted: Wed Oct 10, 2018 5:12 pm
I think an easy alternative would be to buy a few spare rails off the PA and cut to fit. Should be a easy mod.
PostPosted: Thu Oct 11, 2018 10:09 am
I believe so.
PostPosted: Mon Nov 26, 2018 1:30 pm
Please let us know when the parts list for this is available. I want to set up the rear rails on my 2019 Outback like the front rails, including the ability to use my own design for a mount across both for heavier things like a downrigger. Thanks!
PostPosted: Thu Dec 20, 2018 7:22 am
One thing to consider, I tried the h bar clamps from my PA that holds my Scotty mount rod holder, but because the rail is slotted for the t-screw mounts it is not stable enough for the rod holder. I have a Yak Attack Omega Pro mounted via the t-screw mount and it also has a lot of flex in it. It’s fabulous for mounting lighter items, but anything heavier may be an issue.
I love my Hobie therapy
PostPosted: Sat Apr 20, 2019 11:54 am
The part number is 72020153. It is in the new accessories catalog.
PostPosted: Mon Apr 29, 2019 11:27 am
This kit allows you to outfit the cargo area with the same H-Rails that are up front in the cockpit.
72020153
H-RAIL KIT FOR REAR H-TRACK DL
Howie Strech
Parts & Accessories Product Manager
