It is currently Fri Aug 21, 2026 2:09 am
 Post subject: Water Inside Paddle
PostPosted: Sun Nov 04, 2018 11:21 pm
Hi, Newbie here,
I checked the FAQ and searched the forum, but didn't find anything useful, so I hope someone can help me out.
I bought a Quest a while ago and have used it 5 times. This afternoon, while packing up and cleaning off, I noticed that one of my paddle blades has water inside it. When I tip it I can hear it run back and forth.
I guess the solution is to drill a small drain hole. but where? Which end of the hollow part of the blade would be best to have a drainage hole? Is this even a concern? Should it be a permanently open hole? Or should I plug it up with something?
Cheers,
Phil deCube
 Post subject: Re: Water Inside Paddle
PostPosted: Mon Nov 05, 2018 3:01 pm
Should have a foam plug in the shaft. Maybe look in the end and see if your can pull it out.
PostPosted: Mon Nov 05, 2018 4:22 pm
Drilling a hole to drain a paddle is not going to solve the problem unless you fix where its leaking in the first place.
PostPosted: Mon Nov 05, 2018 6:00 pm
Thanks Matt,
Yeah, I had a look. At first I thought it was just in the blade part itself. but I can now hear it running up and down the shaft.
I see the foam plug, but I don't think I'll be able to get it out without wrecking it, so I'll check out the local store for a replacement (or the local hardware store.
It appears to be leaking out slowly through the shaft/blade joint, which I guess is where it's got in as well, so I might have to try and seal that with some silastic.
Cheers,
Phil deCube
PostPosted: Wed Nov 07, 2018 3:18 am
Cheers,
Phil deCube
I had that in a non hobie one piece paddle. I laid paddle flat between two supports, drilled a hole in the middle, hung a weight on the shaft so it bowed making the hole the low spot and left it to drain for some time. Then i smeared some epoxy around the shaft /blade joints. Dont seal the join until water drained out. The seal the hole too.
PostPosted: Fri Nov 09, 2018 8:09 pm
Thanks Waverider,
I'll try that out.
Phil
PostPosted: Sun Nov 11, 2018 2:04 pm
Thanks guys,
I got in touch with Hobie in my country and they told me to take it back to the store, so I did.
See what happens next.
Phil
