It is currently Tue Aug 18, 2026 5:59 am
PostPosted: Wed Feb 13, 2019 12:14 pm
My old Sport takes on water through the rudder line holes if I put a bunch of fish in the cooler. Is anyone familiar with a way to convert the rudder to a twist and stow, or a fix for water coming in the holes (besides losing weight)?
Thanks!
PostPosted: Thu Feb 14, 2019 4:53 pm
Small rubber grommets?
PostPosted: Sat Feb 16, 2019 10:23 pm
If you cut little blocks out of closed cell foam, I use the foam meant for concrete expansion joints as it has small cells rather than pool noodles. Cut a slit in it and slip it over the cable exit point, trimmed for neatness, and silicone/goop in place. Works wonders at keeping water out. If it eventually falls off (mine have lasted ages) just replace with another one.
PostPosted: Sun Feb 17, 2019 8:32 am
Great solution! 8)
PostPosted: Sun Feb 17, 2019 10:16 pm
yep solved that annoying issue of that half a pint of water that always seems to end up in there on a choppy day in the low profile adventure/revo 16 hulls. Should work well on any model
