It is currently Fri Aug 21, 2026 5:07 am
 Post subject: Passport seat issue
PostPosted: Wed Oct 23, 2019 8:18 am
Question for the admins: Is it a known problem about the seat lever latch on the Passport allowing the seat to pop loose if there is pressure placed on the front of the seat? (i.e. I scoot forward on the seat to access my fish cooler bag on the bow). It seems like the plastic just needs to be stiffer or have a metal reinforcement. I've had this happen every time I scooted forward. Not the end of the world, but kind of a hassle on the water to replace while your sitting in the seat. I think the Passport is an awesome kayak, especially compared to the first heavy beast (not Hobie) I had.
2019 Passport 10.5 - Sea Grass
“Do not try and bend the spoon, that’s impossible. Instead, only try to realize the truth… there is no spoon.”
 Post subject: Re: Passport seat issue
PostPosted: Wed Oct 23, 2019 8:35 am
Maybe a small block of stiff foam under the front of the seat to keep it from rocking forward would help. I know that we did stiffen that lever, but think it was before production started.
PostPosted: Wed Oct 23, 2019 9:04 am
Hmmm... Never considered something under the front bar. I'll give that a whirl. Thanks for the quick reply.
PostPosted: Sun Oct 27, 2019 8:02 pm
A little off point, but I use a short piece of a pool noodle (slit on one side to go over the bar) on the rear cross bar of my wife's Passport to change the seat angle for her. I also do the same on the back of the seat frame of my Revolution seat the adjust the height because the flip out legs are a pain to keep in place. I would imagine that a piece on the front bar of your Passport seat would work as well.
PostPosted: Mon Oct 28, 2019 6:36 pm
This is what I ended up doing. I used a 1/2" PVC saddle connector, along with a 1/2" threaded connector and a soft plastic furniture leg, inserted into that for the bottom. I tried to come up with a way to keep from modifying the seat permanently, but I just couldn't keep the legs from sliding out, so I screwed them to the seat. Also, I went ahead and trimmed back most of the saddle, so I just had basically a peg, with a curved, cradle top.
Now, I've already posted this on the Passport FB group, and there's some nay-sayers stating Hobie folks told them the seat latch was meant to pop out and the feet I made, will hurt the deck. My feet are BARELY touching the deck when you are sitting in the seat, so the load is carried along the side rails, just as before, however, if you scoot forward and begin a lever action, the feet kick in to prevent the latch from popping up. I think this will be fine, as I'm only in that position long enough to get in my fish bag cooler on the bow, or stow my mirage drive in the bow section.
https://photos.app.goo.gl/Z4vUpaEosKzZK6uy5
PostPosted: Tue Oct 29, 2019 11:30 am
spanishmack wrote:
This is what I ended up doing. I used a 1/2" PVC saddle connector, along with a 1/2" threaded connector and a soft plastic furniture leg, inserted into that for the bottom. I screwed them to the seat. Also, I went ahead and trimmed back most of the saddle, so I just had basically a peg, with a curved, cradle top.
Excellent solution! Thanks for sharing. 8)
PostPosted: Mon Apr 10, 2023 11:25 am
I created a nice set up with a old piece of vinyl flooring. I stainless hex screw. Hot glue and a pill bottle cap. It never pops out now. Also easy to screw and unscrew.
I did cut down the pill bottle cap some, after filling. I didn't need the whole cap.
See link for pics: https://photos.app.goo.gl/7T4KAJcsgrq6UscW7
Enjoy
