It is currently Mon Jun 22, 2026 5:12 am
PostPosted: Mon Mar 23, 2020 8:27 am
Outback FF Transducer mount for 2019/2020 model
Has any one mounted the standard Transducer XNT 9 HW MSI 150T used on Humminbird Helix 7 Chirp Mega Si GPS G3
Looking for info on mounting this transducer.
Understand there is a kit that allows it to stick down into water but pop up if makes and contact with object?
Also it appears transducer needs to sit below hull some for the side imaging to work good?
Any help appreciated
Paul
Calif
PostPosted: Mon Mar 23, 2020 1:46 pm
Update.
Being have lots of time found a video on U Tube were the plate is modified to sit below plate a little and side scan works
Video title is "Humminbird MSI transducer on a Hobie kayak
Seems simple enough?
Thinking may make a little ramp in front of trans so if hit something goes up easier and protects transducer front better ?? Wont know till installed
PostPosted: Fri Apr 17, 2020 5:29 pm
PJO wrote:
Update.
The little ramp should be included with your boat.
