It is currently Sun Aug 09, 2026 12:23 am
PostPosted: Sat May 30, 2020 5:50 am
Does it work... what is the performance like?
With all that volume in the Getaway hulls I'm sure I more powerful rig would turn the boat into a wonderful performance cat.
Any thoughts or experience on this out there?
Ashus
Mirror, Bosun, Laser, Fireball, Hobie 16, Dart 18, IOR 1 Tonner, 1720, Ozgoose, Hobie Getaway
PostPosted: Wed Jun 03, 2020 6:07 am
Really no views or experience on this?
I know there are many Getaways with H16 masts as the GRP mast tip has failed on the original.
But how about putting the full H16 rig on a Getaway?
It's been well documented that the H16 is overpowered due to its low volume hulls, but the sail plan should work well on the high volume, longer Getaway hulls.
Opinions welcome!
Ashus
PostPosted: Wed Jun 03, 2020 7:36 am
It probably could be made to work. I personally would hate to lose the boomless aspect of the Getaway. The mast placement fore/aft is not identical and shrouds are similarly not identically placed so you would have to be careful of loads and mast rake. The bigger mainsail would likely cause you to need less mast rake which will make the boat more tippy and you won't point as well. It probably won't change the overall performance of the boat by a noticeable amount except on a reach.
R/Thom
SeaRail 19
Triak
BMW C600
Formerly raced F24 Mk II
PostPosted: Sat Jul 18, 2020 8:50 pm
And here I am on Taal Lake answering my own query...
AND Getaway with Hobie 16 mast and Getaway sails
Ashus
PostPosted: Sun Jul 19, 2020 4:41 am
Links didn't work...
Bill P
'00 Wave
Webster NH
PostPosted: Sun Jul 19, 2020 7:22 pm
Try now I'm using a different host
Ashus
PostPosted: Sun Jul 19, 2020 8:13 pm
Looks great except your trim is screwed up (leaches of the two sails should look similar--but that could be just when the snapshot was snapped on the first photo). I like the getaway sails with the taller mast although curious as to the decision to put the anti capsize ball on top again.
R/Thom
SeaRail 19
Triak
BMW C600
PostPosted: Mon Jul 20, 2020 8:36 am
Works now. Good looking rig!
Bill P
'00 Wave
Webster NH
