It is currently Sun Feb 15, 2026 3:23 am
PostPosted: Thu Apr 26, 2018 6:08 pm
Last year I applied the Rail Protection Tape and am contemplating buying the Nose-Rail kit. My question is, will I have to remove the Protection Tape to put on the Nose-Rail kit? If so, how do I do remove it and not harm the surface?
I really enjoy my Eclipse, but I get real nervous when my friends take it out as it is so fragile. I am hoping the Nose-Rail kit will help make it a bit more durable.
Just bought my 2nd Eclipse this year and made it a Dura for this reason. ;-)
Thanks.
PostPosted: Fri Apr 27, 2018 9:05 am
Yes, remove the older version. Apply some heat from a hair drier or carefully with a hot air gun. That will assist in removing the old material.
PostPosted: Fri Apr 27, 2018 9:11 am
Thanks for the quick reply. This is like my 4th Hobie purchase, so I really like your stuff.
Also, thanks for the YouTube video showing how to install the nose-rail kit. I really appreciate you guys investing time for putting these videos out.
Have a great weekend!!
PostPosted: Fri Apr 27, 2018 10:37 am
Glad to have you aboard!
PostPosted: Thu Aug 13, 2020 12:44 pm
Can I partially remove the protective bow cover tape (using heat), repair under it and reapply it?
PostPosted: Thu Aug 13, 2020 2:50 pm
Or remove and replace?
PostPosted: Fri Aug 14, 2020 7:32 am
I just installed the protective tape, while doing so, I noticed a small crack that needs repair. The bow protective tape, underneath, is covering a portion of the crack. I'd like to reapply after I repair, but I'm unsure if the adhesive will still work? Can you advise? I'd just peel it back, repair, then reapply.
PostPosted: Fri Aug 14, 2020 1:29 pm
Not sure at all about the re-use of the adhesive, but you could use a contact cement if you had to.
cron
