It is currently Fri Jun 05, 2026 1:34 pm
PostPosted: Fri Sep 04, 2020 9:39 am
Hello!
I have a friend who wanted to try out my 2008 adventure islander. I hadn’t used my boat in 2 years and found the mirage drive has an issue which needs fixed.
So we were able to insert a 2010 drive, but it took some finagling and is a tiny bit tight. Does anyone know if it would damage the mirage drive well of the 2008 if it is used?
Thank you,
Wanda
PostPosted: Fri Sep 04, 2020 10:59 am
With the alignment pins removed and possibly a little filing of the faring... this will work in the older boats.
PostPosted: Wed Sep 09, 2020 3:52 pm
Thank you!
I will have to brush up on the names for the mirage drive parts :)
My chain assembly had been cut and I was un-able to find one on line, so wanted to use our 2010 mirage drive in it’s place.
Today I looked again. Hobie and numerous other companies are out of stock with this item. Then I happily found one at Outdoor Play!
Thanks Again,
Wanda
