It is currently Wed Jun 10, 2026 3:22 am
PostPosted: Sat Jul 30, 2022 11:41 am
Hi guys I had my Hobie Holder Stored and a tree cam down on the back of the mast. it sheared the fiberglass end off from the aluminum part.
Any pro tips for fixing this correctly??
Thanks in advance,
Mike in Central FL
PostPosted: Tue Aug 02, 2022 8:20 am
I think that the only fix for this is to replace the comp tip (fiberglass portion).
Not really familiar with the Holder but I recently purchased a Hobie 16 with a broken off comp tip that they had tried (unsuccessfully) to attach using pipes and ecpanting foam on the inside and pieces of aluminum screwed to the outside. Nothing was good about this "fix".
There are documents and posts about comp tip replacement on here if you do a search or if someone could share links. It does not look like a horrible project to complete.
Mike
Sailed my first Hobie 16 in May 2022 at 52 years old.
Realized I wasted 52 years of my life!
1977 H16 Tequila Sunrise
1984 H16 Blue Hawaii (My girlfriend's boat but I'll claim it)
PostPosted: Tue Aug 02, 2022 8:40 am
No CompTips are available from Hobie for the Holder / Hobie One in many years. Repair or find a replacement mast from another boat would be the option.
PostPosted: Thu Aug 04, 2022 9:15 pm
TY guys, I'm pretty sure I cant find another mast or just the comp section so we will try a repair.
My initial idea is to remove all the foam from the aluminum side and try to mold anew fiberglass insert to the broken part, making it extra thick and bond it in with new 2 part foam.
PostPosted: Fri Mar 17, 2023 12:32 pm
Hi FLMike123,
I realize it's been many months since your last post. But I have the exact same problem. (But it was snow-load instead of a tree that broke my Hobie Holder 14 Comptip at the mast joint.)
I can confirm your statement that finding a replacement is never going to happen. I sure am curious to how your repair went. Did it work? Any tips? ie what you would do differently?
Thanks in advance,
CaryChildress
