It is currently Sat Jul 25, 2026 9:02 pm
PostPosted: Sat Aug 16, 2025 5:24 pm
I just LOVE my 6:1 downhaul but it's currently rigged with a pin and split ring at the bottom and a pin shackle at the boom. I'd like to make at least one of these easier, like a snap shackle or a captive pin shackle. It's under a fair amount of load (probably gets close to 300 pounds) and the hardware is pretty small.
At the top I think it's not challenging to find something, but at the bottom the post from the block is pinned to a bracket in the mast track and I think you don't want to increase the distance between them. Maybe just a spring-loaded ball pin, if it's not so long that it interferes with anything else?
What do y'all use?
'00 H16 #104691
Old Holsclaw trailer
My Hobie 16 pages
PostPosted: Mon Aug 18, 2025 6:56 am
I see the H17 uses a simple hook to grab the boom slider. Any reason not to use this on the H16?
At the bottom, it looks like the bracket is the same part as the traveler attachment for the main sheet block: DECK PLATE 11870000. I might buy a new one of those (just so the holes are not worn) and use a 3/16 x 3/4 quick pin there.
'00 H16 #104691
My Hobie 16 pages
PostPosted: Mon Aug 18, 2025 8:10 am
On my Hobie 14 beach boat, I have used one of these detent pins to attach the lower downhaul block to the mast fitting for the past several years without issue. It works really well for quick install/removal. And it is lower profile as compared to a ball lock pin. Also with fewer moving parts to jam up with sand.
I have been a little reluctant to try it on our H16, only because we use that boat for racing and I like the extra security of a clevis pin. But based on my experience with the 14, I highly doubt there would be any issue. Once there is a slight amount of downhaul tension, the pin is locked in.
https://www.mcmaster.com/product/98404A006
PostPosted: Tue Aug 19, 2025 8:24 am
Edit/correction to my post below...the upper quick pin that attaches gooseneck to mainsail clew is 1/4 inch diameter, not 3/16 inch (but y'all already knew that!).
Unless I'm mistaken, mine came with skackles/clevises/split rings on both top and bottom. I leave the top shackled to the gooseneck, so the downhaul always stays with the boom. I use 3/16" quick pins to attach gooseneck to main clew and bottom block to deck plate fitting in luff track. They are the kind with a hole in the bowl part where I attach a thin dacron lanyard and secure them to the gooseneck and lower block assembly. Quick pins are expensive, of course, but they make this fiddley task easy...well worth the cost if you sail a lot. Stack height really isn't an issue, but you could probably go without the shackle on the bottom and pin direcltly to the luff track fitting. Not sure if I ever tried that.
Been doing it his way for...I don't know...20 years? Haven't had anything fail, foul or get lost (yet!).
Jerome Vaughan
Hobie 16
PostPosted: Thu Sep 25, 2025 11:45 am
On the top is a standard shackle connected to the gooseneck, the bottom I have a shackle but with a quick release pin (the kind with the button and detent ball).
PostPosted: Mon Sep 29, 2025 6:21 pm
I'm thinking that for ease of rigging I am going to try the H17 hook, because I can then hook it to my main halyard and secure both at once when I am beached mast-up. The bottom I may leave as-is for now.
'00 H16 #104691
My Hobie 16 pages
PostPosted: Tue Mar 31, 2026 8:57 am
How did the H17 hook work out? I’m thinking of the same setup with upper hook and lower quick-pin shackle for the H16
H16 2002 "Islands" Sail No. 107432
PostPosted: Sun Jun 28, 2026 10:40 am
I didn't do it yet, but I'm back on it and ordering parts. East Coast Sailboats doesn't have that hook, unfortunately (I am ordering a tramp from them). Some other places show it out of stock. I guess it's part of the overall Hobie unavailability thing. It's just a simple hook so it can't be too hard to find something that'll work, though. There are options:
52410011 is the H17 Sport downhaul which should be plenty strong enough for me. Murrays has it in stock.
38670010 is Wave downhaul.
38900030 is Wave main sheet and looks a bit more solid.
Ronstan 21-0049 is possibly bigger than it needs to be. 8mm rod.
I will also buy a solid quick pin for the bottom, just to have an option there as well.
'00 H16 #104691
My Hobie 16 pages
PostPosted: Mon Jul 20, 2026 4:02 am
East Coast Sailboats sent me some hook that they had in stock and it works perfectly. I can leave the downhaul attached to the mast and just hook/unhook it from the gooseneck. Perfect. When the boom isn't on, I hook it to the main halyard shackle, which kills two birds with one stone as I haven't had a good place to make the main halyard off to. I will add a quick pin to let me easily remove the whole thing, but it's not a priority.
The next "make this simple" thing attempt will be having a way to make the trap wires off to the base of the mast, which will let me leave them in place and out of the way any time they aren't connected to the bungees. They will all be adjustable, so I can connect them and then tighten them wth the adjusters. No more untangling or having them swing around while I am stepping the mast. It's just an idea at this point. They have in the past been in the way when I tie down on the tailer, but now that I have a two-pocket tramp they roll up in the pockets really well. But having them tight to the mast could be better. Step the mast, move the trap wires to the bungees. Move them back to the mast, drop the mast. Simple. Never swinging around or draped across anything else.
'00 H16 #104691
My Hobie 16 pages
