It is currently Tue Aug 04, 2026 9:44 am
PostPosted: Fri Jun 06, 2008 11:58 am
I drive an '05 Outback and the last time out my rudder would not stay down...(insert joke here :lol: )
Once home, I was able to locate a loose control line which had what appeared to be a loop of surgical rubber tubing on the end. I assume the loop fastens to some fixed object.
Could someone please post a link to information regarding the proper fastening point for the loop?
Thanks!
Mike
"If I'm not at work, I'm Outback"
PostPosted: Thu Jun 12, 2008 6:45 am
Just following up to see if anyone has experienced a problem keeping the rudder in the water due to a loose control cable...
Thanks!
PostPosted: Thu Jun 12, 2008 12:46 pm
Oops, didn't realize you never got an answer to your question. Yes others have the occasional issue with the Twist n Stow rudder system. They work well when adjusted properly, but they don't always come from the factory perfect.
Anyway, you will want to go to the FAQ section. In there, Matt Miller has posted many helpful articles. There are articles on adjusting the rudder as well as replacing the lines (both are up at the top in the first 10 posts). You should be able to look through these articles and see where your loose line goes.
PostPosted: Thu Jun 12, 2008 1:33 pm
Thanks! I found the info as you indicated in FAQ, rudder line replacement.
Now I know where that damn broken zip tie that I found inside the hull came from! :oops:
I thought I must have dropped it in there by mistake... :roll:
Mike
PostPosted: Fri Jun 13, 2008 8:21 am
Hey Ganiom,
Don’t know if this will help answer your question or not, but here are a couple of pics regarding the rudder control lines on my 2005 Sport. Now this was with the older (original) Hobie rudder system, but it may give you some idea of how things are tied together inside the hull, including the function and connection of the zip tie you found. Good luck.
PostPosted: Fri Jun 27, 2008 10:23 am
Great picture. Thanks Apalach. That's exactly the connection I need to make. I may use a heavier zip tie though when I replace the one that broke.
PostPosted: Fri Jun 27, 2008 10:29 am
Hobie Team Member
I'm not sure a heavier zip tie will fit through the hole in the control arm.
Roger
http://www.aldenofsunapee.com/
Image http://www.NEKF.com/
PostPosted: Mon Jun 30, 2008 7:52 am
Thanks, great catch...my bad.
