It is currently Mon Aug 10, 2026 10:20 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Wed Dec 31, 2008 4:09 pm
We're all laughing with you, not at you -- most of us have undergone a similar initiation -- some more than once! 8)
PostPosted: Sat Mar 28, 2009 9:10 am
reconlon wrote:
On the sand should be ok, on the grass even better (cooler), but keeping it on the wheels is not recommended. Using tennis balls on the cart helps keeping it from distorting during regular use.
Yikes!
Mine has been safely sitting in a heated warehouse on her wheels since I put her away for the season 6 months ago. I'll go check her out on Monday to see if there is any hull deformation.
PostPosted: Mon Mar 30, 2009 9:37 pm
There is some deformation, but not much. It's pretty minor and I doubt it will have much effect in the water. Nonetheless I've got the boat sitting flat on the ground now - perhaps it will un-deform over the next few weeks.
Much worse problem discovered. One of the wheels on the cart was destroyed. It is the standard cart with the skinny wheels with plastic spokes. Apparently the load was a bit askew and much more weight was on one side (plus I had most of the accessories lashed to the top -adding to the total weight), the plastic spokes deformed and then gave out, causing the wheel to fold under and the whole deal to list to the side.
So I'm looking for some small utility wheels that I can swap onto the axle. Shouldn't be too hard to find something. I'll look for solid tires again, since I typically launch from concrete and don't want the excess buoyancy of balloon tires.
And I'll definitely be investing in a couple of used tennis balls.
