It is currently Sat Aug 15, 2026 10:08 am
Post new topic Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Balancing Act
PostPosted: Mon May 25, 2009 10:41 am
[quote="BlueMark"][quote="Slaughter
New to PCs and this forum stuff. Had an original Outback and Classic. sold them both for the A.I.. Love the boat and especially this site... (if I can figure out how to use it)
PostPosted: Mon May 25, 2009 11:14 am
Mr. Bluemark-I do actually understand your point. You are also correct in assuming that I dont like pushing against the seat. At one point I could leg press 600 lbs. Thats a lot of pressure to trust to a couple of straps. I have had the straps loosen under pressure so I think a fixed length chain would be better. Pulling forward while pushing MAY give a little extra boost during sprints or when you are against a powerful tide-its debatable.I don`t know. I DO know that the drive unit is designed so well that it can probably take a lot of pressure before the A.I. cracks at the mounts.
My main point is that the molded handles do not provide a good grip.In rough weather(port or starboard waves) you need to counter balance and hold on tight to something. Thanks for your input.
PostPosted: Mon May 25, 2009 3:00 pm
For every action -there is an equal and opposite reaction.
PostPosted: Mon May 25, 2009 3:12 pm
Talking about the various individual pedaling techniques, do you guys actually pull backward on peddles (using the foot straps) after having pushed them forward ?
I tried so and it doesn't seem to be doable from my experience. But I hope there is some trick out there :roll:
PostPosted: Mon May 25, 2009 3:26 pm
Apparently, you can fix that problem with tri-glide buckles.
PostPosted: Mon May 25, 2009 3:39 pm
Thanks for posting-I`ll look into that. And as for balance?
PostPosted: Mon May 25, 2009 3:52 pm
No trick, attach a line from your right peddle to your right grip/arm or left peddle to left grip/arm-whatever. Trust me-these guys are into legs-so leave your arms out of it.LOL.
PostPosted: Mon May 25, 2009 5:13 pm
I dunno Aledal - I thought I had been out in some pretty rough weather, but I have never felt the need hang on tight, except to the mainsheet.
PostPosted: Mon May 25, 2009 5:40 pm
Arno, Roadrunner advocates pulling back on the pedals using the footstraps, but I have never found it comfortable. It's doable if you adjust the straps so they're tight on your feet.
PostPosted: Mon May 25, 2009 6:37 pm
I go faster if I have something to hang on to. This may be an affront to the science of recumbancy but it seems to work for me. Relax my arms and the speed drops -- can't say why.
I've come to learn that even an elite rider doesn't actually generate much force pulling. Here's an illustration -- the resulting force (lower line) goes negative on the pedal return [vertical lines L to R (degrees) 0, 90, 180, 270].
So I think I overestimated the contribution of pulling the pedals back on the return stroke. Just removing some of the leg weight is challenging enough! :wink:
PostPosted: Mon May 25, 2009 7:07 pm
RR, I have a PhD in the science of recumbency, or so my wife seems to believe :roll: .
PostPosted: Mon May 25, 2009 7:49 pm
Then you're just the man I need some advice from! There is a local kayak 5 mile race coming up in a couple of weeks and I'm looking for a way to beat my cross town rival. He doesn't get on these forums often so any advise you give here will be especially helpful! :idea:
I considered an auxiliary electric motor, but am afraid he might hear it. Hiring a boat to generate a nice long wake would be too obvious. If handles won't help, what else is there? :?
PostPosted: Mon May 25, 2009 8:08 pm
Hmmm, You could nip down to the gym and see if you can score some 'roids from the local bodybuilders. If it's a couple of weeks away, you might just have time to pack on some extra beef. There won't be urine tests, will there? :shock:
PostPosted: Tue May 26, 2009 5:11 am
Steroids? Are you crazy? Why risk your health?
Just sabotage the dudes boat.
Simple. :lol:
PostPosted: Tue May 26, 2009 5:13 am
What about strapping a couple of real penguins to the MirageDrive and hanging some live bait over the bow....
