It is currently Mon Jun 15, 2026 10:07 pm
PostPosted: Fri Nov 06, 2009 3:14 am
I changed from an old newcat 14 to a (also old) Hobie 14 T.
I want to use the mast step link, but there are no holes in my
mastbase and the maststep. Is it really succesfull, to drill the holes
for the mast step link in this two parts? How can I find out the
right point to drill in the mast step?
Catsailor1964--Hobie 14 Turbo--sailnumber GER 6296
PostPosted: Fri Nov 06, 2009 9:53 am
You've got the original mast step / base from the late 60's / early 70's - when the only way to step the mast was to muscle it up.
The position of the hole in the mast base is not that critical - just drill it in the center of the "knob" at the aft end.
If your mast step has the rivet for a mast step pivot (hook on the mast base), just drill it out.
PostPosted: Fri Nov 06, 2009 10:27 am
Wow!
Thanks for the first answer in a really short time!
Seems, this forum is as fast as the hobie cats :D !
Great!
