It is currently Fri Mar 13, 2026 4:44 am
PostPosted: Sun Mar 20, 2005 10:25 pm
I have had to tweak the bracket when un steppign the mast, I use a Philips screw driver to step the mast it apears to be solid no damage. I unsteped my H 16 with the pin in the 14 hole. no prolems. what would happen if I steped the mast in the 14 hole :?: I have always been able to allign the holes with 16 when stepping just curious :?:
Todd
 Post subject: Step link
PostPosted: Mon Mar 21, 2005 5:56 pm
Step link...
By using the 14 hole, you would possibly break the mast base as the mast would not be all the way up as the link hits it's stop. The momentum of the mast (26 feet and swinging) can break even the strongest base or link. You also need to be sure the link does not allow the base to over-shoot the cup as this too can break out the back of the base or pull the base out of the mast. Newer links are beefed up to help them stay in shape.
PostPosted: Tue Mar 22, 2005 10:54 am
Thanks Matt That would ruin my trip, day, month til it was fixed. I will keep using the 16 step link and be careful.
Todd
 Post subject: Re: Step link
PostPosted: Sun Sep 04, 2005 10:00 pm
Mr. Miller,
I managed to break the mast base step pivot. Having not yet contacted the nearest Hobie dealer for the mast base replacement cost. What's the feasibility of removing the mast base and having the pivot rebuilt at a welding shop? (Experience working with cast aluminum of course).
Thank you,
Eric Abbott
mmiller wrote:
Step link...
PostPosted: Mon Sep 05, 2005 8:25 am
Rebuild / weld the mast base?
Not sure about welding on castings. There is a significant lever load when stepping the mast, so hopefully the welding shop will know how strong it can be.
PostPosted: Mon Sep 05, 2005 9:07 am
Welding typically leaves residual stress in the metal. Part of the strength of the castings comes from the way the metal crystalizes when cooled. Also, any kind of heat treating of the metal will alter the strength of the part.
It would probably be a very good idea to replace teh mast step instead of welding it. Especially if the part is from an older boat. Better safe than sorry, especially when dealing with stepping a mast.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
PostPosted: Mon Sep 05, 2005 8:09 pm
All,
Thank you very much for your advice and commentary. As usual, I'm checking my options. A replacement mast base should be on its way very soon (the earlier the better).
Many thanks,
Eric
P.S.
From one newbie to all other newbies: Bring a "righting bag" if you feel inspired to venture out by yourself. Especially if you weigh less than 200 pounds (like me).
