antadi wrote:
I have a 2015 Revo 13 and am thinking of getting a second boat. I want a Revo 16 if it is actually faster.
The Revo 16 is definitely faster, but at about 4 MPH you might not notice it so much. Because you're not pushing the "hull speed" on either, the length/width advantage of the Revo 16 doesn't manifest itself as it would as, say 5.5 MPH. the faster the speed, the bigger the difference.
I think for the 16 to be faster it would have to put out less of a wake than the 13 by having the water tapper off the back of the boat better.... could not believe the wake it makes at 4 mph (my cruising speed). The water was flat the day I took the picture and you can see swells behind me. The sea kayaks I travel with sometimes do not leave much of a wake at all. .
Interesting observation. In a way you're right, but it's a little more complex than that.
First of all, the Revo 16 has less stern wake at any given speed than the Revo 13. because of the length/width difference.
Second, there are two wakes -- bow wake and stern wake. Turns out the Hobies generate less bow wake and more stern wake than most comparable "sea kayaks". For instance, lets look at the bow wake of a comparable Heritage Nomad (16' x 28" sea kayak) compared to the Adventure (Revo 16) at approximately the same speed (about 5+ MPH):
Nomad bow wake:
Hobie Adventure bow wake:
Nomad stern wake:
Adventure stern wake, running about 5.6 MPH (trying to outrun the ghost in the wake)
Your Revo 13 by comparison running about 5.3 MPH:
As you can see, the Revo 16 puts out less wake even though it is going faster.
Part of the reason for the difference in wake patterns in the Hobies vs. traditional kayaks is the typical Hobie design (less rocker than most sea kayaks) gives more hydrodynamic lift to the forward portion of the boats. This is exacerbated by the thrust source coming from underneath the Mirage boats. As a result, Hobies tend to "squat" a little in the stern as the bow lifts with speed, generating more stern wake. You can actually increase your cruise speed to the extent that your bow comes out of the water by adding weight to the bow. The amount varies with speed, model and weight distribution. I usually use 10# on the Revo 11 and 5 to 7# on the Adventure (greater leverage due to length). The best way to determine what is best for you is to have someone check your bow at cruise speed). You want it to be in the water. This keeps your waterline length from shortening -- a much more important factor in speed than the weight itself. Using this technique, I get about 1/10 additional MPH -- not huge, but it adds up over time!
Although the Revo 16 is a wetter ride in most cases than the Revo 13, you should find it to be faster and more seaworthy than the 13 -- an excellent cruiser, the fastest single seated Hobie and faster than any
comparable length paddling or pedaling kayak (race proven)!
