It is currently Thu May 09, 2024 11:10 am
PostPosted: Thu Jun 14, 2018 5:04 pm
Any advice on a quick and easy way to make the hulls look a little nicer? I don't want to sand anything, just want to know what products people use to make the hulls a bit cleaner and nicer looking. I have white hulls with a black stripe.
PostPosted: Fri Jun 15, 2018 9:27 am
I have not tried it on mine yet but seems Starbrite is used by others on the forum. Do a search on the site for restoring / cleaning and you should find some more info.
84 14T Redline #67 Blue Hawaii faded but still working!
82 Yellow hull16 '81 Boomer nationals 20.9 on GPS
83 White hull 16 No sails "Clean and Purty Now!"
87 White hull no sails no tramp
PostPosted: Mon Jul 16, 2018 10:02 am
Starbrite, or any other product containing Oxalic acid, will clean out the pore/pock/pits in the gelcoat caused by UV
my go to is Bar Keepers Friend, located next to the Comet abrasive cleaner at the hardware store
they have a "liquid" version, but you can add your own water to the powder version and slather on a paste
1984 H16 "Mister Rogers"
1984 H14 "Sundays"
2000 H20 "Jet"
Sheet In, Max Out
PostPosted: Sat May 18, 2019 3:54 am
"Slimy Grimy", sprays on, you can rub the worst spots with your fingers or hand, hose off. You won't believe how well this stuff works on fiberglass.
Buxton
18' T16 Silent Lightning (16' T2 Hybrid)
11' H16 White Lightning
79' H16 Green Lightning
PostPosted: Tue Oct 15, 2019 12:49 pm
What do you think of the 3m marine restorer and wax or this?
Sent from my LM-G710 using Tapatalk
PostPosted: Wed Feb 12, 2020 4:30 am
As for the getaway with rotomold. I found it easiest to wipe down with uv protectant with a magic eraser. Only thing I found that would really make the boat look new again
PostPosted: Thu Mar 12, 2020 9:15 am
Goof Off - RustAid is very good at removing the brown stains - mainly from organics (naturally occurring humic, tannic and fulvic acids, etc.) in the water as well as removing rust on boats. It is safe for fiberglass, etc.
Very easy to use: Mix 3 parts water with 1 part Goof Off - RustAid in a 1 gallon hand pump sprayer. Spray on Hobie, stains disappear in less than a minute, then rinse off. Recommend wearing eye protection.
Available at Lowes, Home Depot, etc. at less than $10.00 per gallon. Also 1 gallon plastic hand pump sprayer for less than $10.00 which can be used many many times (if rinsed out after each use).
Active Ingredients: Oxalic acid <10% and Hydrofluoric acid <0.5%
Tim
84 H16
82 H16
87 H14T
Tortola Sails: 115222
Blue Prism Sails: 88863
Clearwater, FL
PostPosted: Sat Mar 14, 2020 7:29 am
One thing no one has mentioned but it SHOULD be stressed.
If you don't wax the hulls after you deep clean them you are not protecting the glass from future stains, grime.
PostPosted: Tue Apr 28, 2020 8:31 am
Don't leave that RustAid on metal parts for long - has a small amount of Hydrofluoric Acid. Nasty, nasty stuff but really diluted here. Still, it'll pit stainless in low concentrations if I remember correctly.
ChuckC
H21SE- 408
PostPosted: Fri Aug 14, 2020 1:04 pm
I use Oxalic acid it works great on fibreglass boats and is cheap.
Hobie 14 Turbo (~1979)
Hobie 16 Carumba (1983)
Hobie 16 1990 (storm damaged)
Hobie 16 1996 (my latest)
PostPosted: Sat Jan 14, 2023 11:22 am
Nobody has brought up one point, but it needs to be emphasised.If you don't wax the hulls after you've given them a thorough cleaning, the glass won't be shielded from dirt and stains in the future. Earning.
Thank you .
