DVL wrote:
Look at your knot or splice. It must be tight against the ring. I did a nice splice on my line but it gets tight at the top due to the extra thickness. New lines are stronger so you can drop a diameter. Just wear gloves when raising the sail.
i'll take a look at it again, i got a new line i replaced on it, which is alot thinner than the original one, and yes gloves are a must, i learned it the hard way /ouch
hobie18rich wrote:
look for a tear in the bolt rope at the joint of the comp tip. if there is a taer in the rope it may catch at the comptip joint. make sure the track is clean.
well the rope is new, and i did try to inspect the track as much as possible, i'll get a hose and try to pressure washer it out, maybe something is in there i dont see from the outside.
jsserene wrote:
Are you sure about the year and model? The Hobie 18 did not start
production until September 1976.
well to be honest, when i bought the thing from this guy he said it was like a 1990s model, when i went to go register it, they said it was a 1973 model , i know its a 18' but maybe the people when i went to go register it, they had it in their wrong. i looked at the tailend of the boat where you can see the numbers, a few of them are unreadable, i even try to take a pencil and use a piece of paper to try to fade over the numbers still a few you can quiet tell.
doesnt really matter i guess =) but thanks for all the input and help everyone=)
