Congrats on what sounds like a fun first sail!
Sailing from a ramp can be a lot more challenging than sailing from a beach in my experience, though it's my primary means of sailing my boat. It's definitely easier off a beach or with an offshore breeze, though it can be done with an onshore breeze as well, but you also need some room to either side of the ramp... Having a pier alongside obviously makes things pretty difficult. If you don't have enough room to tack and jibe, I'd suggest finding a different launch.
Getting away from the ramp, of course, I'd turn the boat to face into the wind once you get it off the trailer, hoist the main, and try to walk the boat out to the very end of the dock or as far from the ramp as you can. Start with the main loose and jib furled. If you can give the boat a "running start" either off the dock or ramp, so that you have some flow over the rudders and some steering, that would be helpful. As soon as you clear the dock, start to turn the boat off on a close reach, unfurl the jib and bring it in on the proper side... this helps to turn and starts the boat moving forward. As you start to move forward, start to sheet in the mainsail.
When tacking, you've got to remember that your sails will overpower your rudders every time. Therefore, keep your speed up into the turn. As soon as the jib goes slack, release the sheet and start bringing it across, but keep the main in TIGHT. As soon as you're perfectly head to wind and the main sheet goes slack, LOOSEN the mainsheet and let it out a foot or two. This way the mainsail doesn't fill before the jib and stop the turn. At the same time, bring the jib in quickly and keep the rudders over... you need the jib to fill first to both help you complete the tack and start regaining momentum again. Once the boat starts accelerating, bring in the mainsheet. Sometimes it helps to dip down to a close reach in the tack, and then come back up to close hauled once you regain momentum.
Landing at a ramp in an onshore breeze can be dangerous if you don't plan it out in advance. With the wind filling your mainsail, you won't be able to stop the boat by grabbing onto the dock or jumping off in front of it, no matter how light the wind seems. DON'T TRY IT. Similarly, sheeting in the main to bring it amidships never seems to work, and can sometimes turn the boat/overpower the rudders. The best way I've come up with to land at a ramp in an onshore breeze is to furl the jib, turn the boat head to wind just ahead of the dock, push the main out to one side and use the rudders to BACK in to the dock/ramp. If all else fails, you might have to unfurl the jib, sail back upwind, and try backing down again, or jump in the water once you're shallow enough and walk the boat in.
_________________ Mike '79 H18 standard ' Rocketman II' sail #14921 RIP '78 H18 ( unnamed) sail #14921'08 H16 sail #114312'97 H21SC sail #238
