Sabres has a good point....the old style rudder system had some definite quirks (i.e., it doesn’t work very well). If you over-tension the adjuster in the casting, the rudders won’t kick up and you’ll either break the casting, rudder pin, rudder, or transom if you hit bottom. My current boat has the new system, but I sailed an 18 with the old system for a couple decades. We always ran the springs at almost zero tension and instead used bungee cords around the rudders with the kickback “washers” on the lower rudder casting bolt to provide the majority of the rudder hold-down force. Murrays sells them as the Kisme Kleet.
All that said, I think you may still want the spring installed in the lower casting to help keep the upper casting latched down. I would think without the spring the tiller arm may want to lift accidentally which would be annoying at the least. A bungee cord may be able to be used as a substitute.
I also just checked my garage and have two of the old castings (with springs) I’d be willing to part with at a reasonable cost. PM me if interested (you would have to take the whole casting though, not just the spring).
