There are two spins that can be used on the 18 with ease. First is the SX spin setup, the pole is shorter and the sail fuller. The sheet system works off the rear crossbar or preferably off the wings. The Tiger system has many different shape and sized sails available and the pole is 12'. The sheet system works off the shrouds or deck and the front crossbar.
If you go to the Hobie Europe site there are Tiger spin install instructions. Its really not that hard to do but proper measurements can and will be tricky. Your sail actually determines alot of the placement of blocks, bails, etc.
A Tiger spin on a standard 18 mast will be more of a head sail, its too long. You could have it cut down perhaps or have one custom cut, not too bad $1k or less. I switched to an SX mast which is 29'6", a standard 18 is 28'. There is always some compromise when creating a hotrod sailboat.
I think it is worth it no matter how you get a spin on the boat. Another thought is too use a hooter type sail instead, check out catsailor.com for info on hooters. They sell and design them, maybe even invented the idea for beachcats.
Later
