It is currently Thu May 23, 2024 2:38 am
PostPosted: Sun Apr 21, 2019 8:58 am
1. If I use a hole saw to drill a hole on the Compass in the same spot where the 2019 Outback has the cart keeper cleat, is there a chance I hit any rudder cables or anything important?
2. What size hole saw do I need?
3. Does this void the hull warranty?
Part seems to be:
#71117001
CLEAT - SCREW-IN
PostPosted: Tue Apr 23, 2019 5:48 am
Sorry I'm not going to be much help with the hole size or location of cable. I have used my phone and put it inside the nearest hatch and shot a video of the area I wanted to drill into before and it worked out well. This will give you a visual of what's behind the area you want to drill into. I am almost certain if you drill into your kayak it will void the warranty.
Hopefully someone else can chime in to confirm.
