It is currently Sat Apr 27, 2024 12:20 pm
PostPosted: Thu Sep 29, 2022 3:24 pm
I have a Compass Duo which I will be using with a new Yakima Easy Rider trailer. I would like to use the trailer for transport and storage, and it is much easier to load the kayak hull down since I am the only person over 10 years old in the family. I have the compass duo cradles, which seem to fit best around 74 inches or so apart. My issue with the trailer is that the lower crossmembers after 78 inches apart, which seems like that is a bit far to try to support the weight evenly.
I have crossbars on the upper level of the trailer that have a maximum spread of 60 inches.
So at this point, I can mount the cradles either 60 or 78 inches apart--have either of these distances been uses the the cradles safely. Personally I would think having the cradles at the 1/3 and 2/3 distance would make the most sense, and that would be a spread of around 54 inches about center.
I have a yakima big catch also, but don't view that as being good for upright storage.
What do others use for the crossbar spread for a compass duo, and do you store it upright with cradles?
Thanks for your help.
PostPosted: Fri Sep 30, 2022 5:03 pm
In the post below Matt affirms best spacing at 1/3 hull length. For your Duo that would be 54" as you concluded.
https://www.hobie.com/forums/viewtopic.php?f=138&t=64841
But best fit may not be at exactly 54". In this video Howie shows how to find the correct spacing and contact locations.
https://youtu.be/KrX9tNSKSLo
Peter
2016 Hobie Oasis with Evolve v2 rudder mount, Sidekick ama kit, Mirage sail kit, Garmin echoMAP CHIRP 42dv, bilge pump
2007 Hobie Outfitter x 2 with Mirage sail kits, large rudder blades
