It is currently Fri Apr 26, 2024 6:27 am
PostPosted: Mon Mar 19, 2012 6:03 pm
Was looking to update my single block setup with a triple. Naturally i'm looking for the best deal and came across an upper and lower triple block from a company called Nautos. Their lower block (part #92733) sells for around $90, and their upper (part # 92230) goes for about $50. Much less then a Harken setup and both blocks are 57mm. Of course the ol' "you get what you pay for" line runs through head so I was wondering if any of you have experience with, or an opinion on this company and their products since they seem to be a lot less expensive then Harken.
PostPosted: Mon Mar 26, 2012 4:13 pm
I came to this forum with the same question about Nautos blocks. I saw your post and was disappointed to see no replies. Anyway, I found a Nautos distributor in St. Pete that gave me little more info. Though I'm not ready to buy blocks yet he gave me a little better insight into Nautos. A phone call may help you decide.
There are a few dealers listed on the 'Dealers' tab on this site.
http://www.nautos-usa.com/
PostPosted: Mon Mar 26, 2012 7:40 pm
I have very limited experience with Nautos blocks. I've only owned very small ones (18 mm) used for control lines (like the jib tack tension on a Tiger). They are very similar to the Holt-Allen (British) blocks and I've seen references to Holt-Nautos on the Internet. Not really sure what the connection is.
However, 57 mm is too large for the upper block. Stock size is 40 mm. (Harken 2643).
I will say that Harken blocks are made in the USA; Nautos blocks are made in Brazil. Harken will replace a broken or malfunctioning block, no questions asked (other than trying to figure out why it broke so they can make their products better).
PostPosted: Mon Apr 30, 2012 7:00 am
Thanks for the heads up on Nautos. I just bought a 57mm Nautos 6:1 ratchet setup over the weekend. The ratchet base and triple boom block cost me $129 including shipping. They come with a 5-year warranty. I love Harken products but a similar setup from Murrays would have cost me three times what I paid for these blocks. Time will tell if I made a wise investment.
PostPosted: Mon Apr 30, 2012 8:19 am
I a very interested in what you think of them after you see them and use them a little.
I am a big fan of 'Buy American', but really don't want to drop $350 on blocks. I would find a used set first.
Steve
PostPosted: Wed May 02, 2012 7:15 am
I had a Harken 2655 break on me last night. It is the upper block in the Aussie halyard setup.
I called Harken this morning and they informed me there was a only a 5 year warranty.. But only asked that I send them the block with a description of how it was being used, and a replacement would be sent.
www.thehobiewayoflife.com
PostPosted: Wed May 02, 2012 9:04 am
The Harken 2655 (40 mm Carbo fiddle) is an marginal choice for the Aussie halyard system on a 16. It only has a 485 lb working load and a 1620 lb breaking strength.
A better choice is the Harken 100 (double bullet block for wire). It has a working load of 750 lbs. Pair it with the Harken 099 (single bullet w/becket for wire). Both of those have a 2000 lb breaking strength.
PostPosted: Wed May 02, 2012 11:59 am
Besides having a replacement on the way... I am pretty sure I just ordered what you are suggesting. Jim Sohn is setting me up. :D
so given that my experience seems to reinforce what you are saying.. maybe this needs updated...
http://www.harken.com/OneDesign/hobie16.php
Sorry about the thread highjacking.. just wanted to put in my 2cents about Harken's service...
PostPosted: Wed May 02, 2012 3:21 pm
Update: The $129 Nautos blocks I ordered on Saturday were shipped from Ft. Lauderdale at 9AM on Monday and arrived at my house this afternoon via Priority mail. So far so good. A pleasant surprise - they came with nice SS shackles. I didn't expect that. They basically look like knock-offs of the "other" brand. :P
PostPosted: Thu Apr 02, 2015 11:00 am
Hey I have the same dilemma with Harken vs. Nautos. Can you please share your experience wit the Nautos brand. Would you recommend it?
Thanks.
PostPosted: Fri Apr 03, 2015 8:21 pm
I just picked up a Nautos mainsheet ratchet block for my Sunfish. Seems to be good quality from what I can see. I'm curious to see if it compares to the Harken on my other boat. I'll update once i have some wear and tear on it.
PostPosted: Sat Apr 04, 2015 7:49 am
Thanks.
My experience has been very positive. I can only speak for Nautos "Classic" line but I can tell you they are excellent blocks. The blocks I replaced were Harkens. You can't tell the difference (apart from the fact my ratchet now works). I went with 57MM for my H18. H16 sailors might need a smaller stack due to the significant mast rake.
PostPosted: Fri Nov 10, 2017 12:10 pm
Any updates on use/wear of the Nautos triple blocks? My Harken triple rachet died (so much for buying the best) and needs a replacement. I am using them on my 14 but should be the same as 16.
Also going to replace the main sheet.
Is Salsa 8mm still a popular choice or has it fallen out of favor for something newer?
Noticed Hobie is now supplying the Getaway's with Nautos blocks. Saw a new boat which had them. Owner said it came that way new.
Is the current setup 57mm on the bottom and 40mm on the top?
PostPosted: Sun Nov 12, 2017 3:10 pm
I've used OEM Nautos mainsheet blocks on the T2 for the past two years and I think they're great so far! I'm guessing they were a carry-over from the European Tatoos.
PostPosted: Tue Apr 10, 2018 8:37 am
Agreed. Got a set last summer and am very happy with them.
Georgia (west)
Hobie 16
