Had some questions about the ramp I use to get my H16 over a rip rap seawall. This is FAR from fancy, but it works. On Lake Norman the level goes up and down almost 10 feet; if I was building it again i would make the ramps longer for when it drops really low. I would also make the ramps wider to make it easier, and out of structural aluminum I could find some without breaking the bank, but have decided to sail instead of build new ones
Pic 1: I keep the ramps next to the launch; technically not supposed to keep them in the water for long so they just drop into the end of the launch when ready. They stay in the water until I come back from sailing.
https://drive.google.com/file/d/1xMJqa0T0850mL9VWdfzVuFP3-KzBT4V6/view?usp=sharingPic 2: Port side ramp about to roll down the rip rap. Its just pressure treated 2x6's with 10" tires from Tractor Supply on the end (so they float, and to make it easier to get down the rocks). The rollers are 1.5" PVC screwed into the 2x6's with a shorter section of 2" PVC inside for cheap rollers. The last one (the handle in this pic) is just 1.5" and is bolted through to keep it place; this drops into the launch when deploying the ramps
https://drive.google.com/file/d/17xQ4qweW4yl0oofG3L7ZOFHw-G7sZKBD/view?usp=sharingPic 3: One of the ramps dropped into the end of the launch
https://drive.google.com/file/d/1X-oM5pYcqoeudHg8nMRur5OH7OgiqdPx/view?usp=sharingPic 4: Close up of the back of the launch, I used 2 8" trailer rollers per side which helps when the boat pivots onto the launch. A couple of wedges wrapped in outside carpet keep the ramps in place, just drop them in.
https://drive.google.com/file/d/1it52fsxybxJ4jDR8rkubTrSv1IynU_K5/view?usp=sharingPic 5: Ready to send 'er down the ramp
https://drive.google.com/file/d/1wuCy0N0bmpeHqEbbCwQWqI4PaB_Y3Agj/view?usp=sharingPic 6: A winch on a 4x4 post cranks the boat up and down the ramp. The previous homeowner had this post here for a birdhouse, so I get lucky with the placement!
https://drive.google.com/file/d/15ILPx3ajz-jGp887CVUHuKbLh83qly1G/view?usp=sharingPic 7: Last one, this one shows the launch structure as the boat goes down the ramp. I wrapped the 2x4' cross members with some outside carpet to make it a little easier on those old hulls.
https://drive.google.com/file/d/1ZJW2YLjHGtXhtBDSqAhuEY2SsmQLFx3c/view?usp=sharingHope thats helpful to somebody. Let me know if you want any measurements.
