It is currently Tue Jun 04, 2024 8:32 am
PostPosted: Mon Jun 28, 2021 7:52 am
Hi all,
Hoping for a good answer from the forum for my question. I have an old '77 H16 and the mast base is cracked at the hole where the step hinge goes. Not all the way, but I'd like to replace it for mast stepping safety. If I buy a new Hobie mast base will it be compatible with my old mast step?
Many thanks,
Bryan
Poplar Grove, IL
1977 Hobie 16 (died a spectacular death https://youtu.be/Y7O22bp2MVA)
1978 Hobie 16
PostPosted: Fri Jul 02, 2021 3:15 am
I don't think a '77 is much different from my '85 H16. Just replaced the original mast base, and not the mast step, with a new one without any issues of mast rotating.
I've heard that sometimes the older mast steps don't always match up well with newer mast bases because Hobie has increased the mast rake over the years a couple of times. This could cause the two to bind where the casting for the pin hits the step, possibly keeping the mast from rotating while sailing.
Hope this helps some...
Image Image
'89 H14 'Jaws'
'85 H16
PostPosted: Fri Jul 02, 2021 7:49 am
Thanks Robie!
Bryan
Poplar Grove, IL
1978 Hobie 16
