It is currently Sun Apr 28, 2024 1:47 am
PostPosted: Mon Jun 21, 2004 6:40 pm
Looking at an older 16 as a rehab project. First do they carry a serial number or date of manufacture code? Is there a series of older 16s that a person should avoid? This 16 has been stored uncovered on the beach in Virginia for at least 6 years. Fiberglass looks pretty rough, of course needs a new tarp. Mast looks okay and hardware appears that it will clean up okay.
Any help would be appreciated.
PostPosted: Mon Jun 21, 2004 7:40 pm
If there's no serial on the back of the hulls, look on the front left pylon. That's where mine is, 1972 boat, hull #3404.
Jim
PostPosted: Tue Jun 22, 2004 9:14 am
Hmm... I don't think there are certain model years that need to be avoided. I would recommden not to get a pre 84 boat if possible - starting in 84 the weight limit changed - resulting in lighter hulls. I would recommend to look for soft spots on the hulls - that is a standard defect on older hulls. Check the bottom of the hulls for wear. Check the sails if they can be reused. Find out if you get some upgrades - like harken 6:1 main sheet system, beach wheels, trap wire or seat, ... Keep in mind that you will spend $300 for the tramp, >$50 for main and jib sheet and $xxx for some other bits an pices. It looks like it comes with out a trailer and you seem not to get the title (since you do not know the age of the boat). Find out what it means in your area not to have a title. With other words ... do not pay more than a few hundred $$$ for the boat - you will need some money and time to get it ready to sail.
Patrick
PostPosted: Tue Jun 22, 2004 9:32 am
This is in the FAQ section of our forums...
Includes all kinds of information on serial numbers.
http://www.hobiecat.com/community/viewtopic.php?t=86
PostPosted: Tue Jun 22, 2004 10:02 am
It'd be great if you could expand that to include the serial numbers by year (and month?) for the older boats with hull #s on the pylon.
Hint hint hint. 8)
PostPosted: Tue Jun 22, 2004 10:46 am
Records of serial numbers of the older boats (older than 1973) are not available.
PostPosted: Fri Jul 02, 2004 7:14 am
My first question would be how much are they asking. Buying a Hobie with the parts on the boat or in the sailbox is typcially a much better deal than trying replace worn out parts with new. A new tramp has to cost at least 400. I have bought three Hobies off of local lakes. I considered the last two to be good deals. I paid 700 for the second boat and it was i great condition. I had to buy cat tracks from someone that cost 200 used. I sold that boat to a buddy and he still has it. I recently bought a replacement boat for 1200 but it had a nice sailbox on the trailer and the cat tracks were included. Both had tramps that were in good condition. The condition of the sails is a big deal. Stiching, battons and the leading edge which fits up into the mast when you raise the sail can get worn and often needs attention. If I were going to look for a new used boat, I would definately lean towards finding one on a lake.
