It is currently Thu Jun 06, 2024 3:32 pm
PostPosted: Thu Mar 04, 2021 2:48 am
I have noticed that there is movement between the mirage drive housing and the hull whilst pedalling.
This footage was taken on the 3rd time I have used the passport but I have noticed it since new.
It seems like a small issue but I worry that the continual movement will cause problems in the
Please see the below youtu.be link:
https://youtu.be/SnOnKOgrwTE
PostPosted: Thu Mar 04, 2021 4:20 pm
Should be able to tighten it up from the underside. Screws.
PostPosted: Thu Mar 04, 2021 4:51 pm
Awesome, I will have a look. Thanks
PostPosted: Sat Mar 06, 2021 3:36 pm
I tried and got about 1/4 of a turn on each screw and they are pretty firm but there is still the same movement when pedalling.
PostPosted: Mon Mar 08, 2021 4:05 pm
There is a just a bit of play in most of these. It doesn't really harm anything. Under pedal power the drive will be thrust against the hull and you shouldn't notice the play.
PostPosted: Mon Mar 08, 2021 4:24 pm
I only notice the play when under pedal power. My only concern was if it was not normal and may develop but if you think this is normal movement I am happy with that. Thanks.
PostPosted: Tue Jun 28, 2022 5:08 am
it does the same on my new 2022 Passport 12.
