It is currently Sun Apr 28, 2024 9:01 pm
PostPosted: Sun Apr 23, 2017 3:07 am
I put a hole in the boat to fix leaking rear wing tubes.
Now i also have the possibility to fix the foam blocks that clunk around inside the hull.
I know it's not really a matter to pay any attention too, but it would be nice to have them fixed.
Anyone with ideas how to stop them from sliding around?
//Mats
Just picked up a Hobie FX One...
PostPosted: Sun Apr 23, 2017 6:40 am
Just a thought, but if you can get to them I think i would try to get some Marine expanding foam or an equivalent, and try to get some under the blocks or on top. You will have to be careful not to use too much because there could be a hull distortion if you went crazy. 3m makes an automotive product that is two part, it is a non structural pillar foam that is used for noise reduction. Because its non structural there would be very little chance that it would cause any problems. It dries to a soft squishy foam that is water proof or resistant.
