It is currently Fri May 10, 2024 5:02 am
PostPosted: Fri Apr 19, 2019 6:39 am
I have consulted the FX1 parts manual only to find a photo of a yellow line threaded through the mainsheet system and a ref 17560419. Does anyone know the specified line diameter and length for the mainsheet? Also what was the original purchase of the mainsheet system 7:1 or 8:1? The boat I'm working on right now has an older style Harken 7:1 that does not run well. I'm considering going 6:1.
Thanks in advance,
Hobie 16 (3 formerly)
MacGregor 25 (formerly)
Chrysler Dagger 14 (formerly)
NACRA 5.0 (currently)
High Point, NC
PostPosted: Mon Apr 29, 2019 3:27 am
I can measure my FX1 length and diameter the coming days.
About main sheet system:
i have two triple blocks and each fitted with a single block attached to give higher purchase.
//Mats
Just picked up a Hobie FX One...
PostPosted: Mon Apr 29, 2019 10:09 am
//Mats
Thanks in advance.
High Point, NC
PostPosted: Wed May 01, 2019 2:17 pm
After checking today:
Length: 13 meters sharp
Diameter: 12 mm
My main sheet is as on your picture - same color and i assume it's original (except the difference in the blocks i wrote before)
//Mats
PostPosted: Wed May 01, 2019 8:42 pm
Diameter: 12 mm
//Mats
Thank you very much!
High Point, NC
