It is currently Sat Jun 15, 2024 6:58 pm
 Post subject: H14 Turbo Jib
PostPosted: Mon May 12, 2014 3:35 am
I'm considering buying a H14 Turbo. I would like to leave it on the beach all summer. Rather than to use a snorkel to protect the jib, is the jib easily removed like the H16?
Eric
 Post subject: Re: H14 Turbo Jib
PostPosted: Mon May 12, 2014 5:54 am
The jib is also the forestay on a Turbo. Removing it drops the mast. A snorkel is pretty simple to use. I wouldn't leave the jib on without it. I've seen several Turbo jibs shredded on the beach by wind storms after the furler line shakes loose from its rinky dink little cleat.
PostPosted: Mon May 12, 2014 10:33 am
I always tie off the furler line, even for a short stint on the beach! Nonetheless, a snorkel's easy to use and also protects the exposed portion of the sail from fading and UV degradation.
Dave
PostPosted: Tue May 13, 2014 4:23 pm
I use a small bungee cord to keep the jib tightly furled while on the beach. It's not as good as covering or lowering it, but it's quick.
1985 Hobie 14T
2014 Hobie T2
PostPosted: Thu May 15, 2014 2:14 am
Over the winter I converted my H14 to a Turbo, but I rigged mine as a "Mini 16". It has no roller furler and utilizes a separate forestay and jib halyard system like an older (pre-Aussie halyard) Hobie 16. It works great and allows me to remove the jib when I'm not sailing. Here's a link to how it's done: http://midwestsailing-teh.blogspot.com/ ... erger.html. I modified some of the measurements on the rigging based on my own second guessing, but it works great. If you send me a private message with your email address, I can send you the rigging measurements that I used. My motivation for going with the Mini 16 rig was that I didn't want to leave my jib up all season either. My boat is stored mast-up. Even Hobie tells you in their catalog that the jib snorkel is not intended to be a permanent storage solution.
Mark Van Doren
H14T Fantasia #47787
San Juan 28
PostPosted: Thu May 15, 2014 12:00 pm
The 14's pretty easy to step the mast! I store mine short term with the mast up and snorkel on. Longer, I put the mast down. I don't race very often, but still wanted to keep her pretty much stock.
Dave
PostPosted: Sat Jun 20, 2015 1:23 pm
Okay. Been 30 years since Hobie sailing on 16 and now my son and I are venturing into 14T. How do you put the snorkle on furling jib?
PostPosted: Sun Jun 21, 2015 8:18 am
Bully: First of all, when you lower the mainsail, make sure that the nicopress slug doesn't run inside the mast track on the way down. Otherwise, this method won't work. Once the mainsail is down, attach the top of the snorkel to the main halyard shackel, zip up the snorkel as it's raised, tie the bottom off somewhere near the furler, and cleat the main halyard. A word of caution: In stronger wind, the furled jib/snorkel can hit some frequency that makes them (and the whole boat) shake almost violently. After the main halyard is cleated, we run the excess line around the furled jib/snorkel a few feet above the furler, tension it enough to remove slack in the rig, and recleat. Doing this seems to help a lot.
There are probably other ways to rig the snorkel, but this one works for us.
Jerome Vaughan
Hobie 16
