It is currently Sun May 05, 2024 6:37 am
PostPosted: Tue Jul 20, 2021 10:59 am
I just bought a used Hobie Cat 14.
I need help threading the blocks
The top block is a double and is where the rope ends in a knot. The bottom block is a triple with a ratchet in the center.
There is no clew on the bottom block.
I've watched countless of videos but none where the blocks are different sizes.
Can someone help me?
PostPosted: Tue Jul 20, 2021 4:29 pm
You have basically the same as a 6:1, but the line stops at the top block instead of returning to the lower. So steps 1 through 6. At 6, tie to the becket on the upper block.
PostPosted: Wed Jul 21, 2021 1:47 am
Thank you so much!
Do I need a clew or is the center ratchet sufficent?
Jenn
PostPosted: Wed Jul 21, 2021 5:14 am
Not clew. Cleat. Do I need one if the bottom block’s center is a ratchet?
PostPosted: Wed Jul 21, 2021 8:18 am
You don't "need" a cleat, but they make the sailing much easier on your hands / arms. Holding the sail load all the time is fatiguing.
PostPosted: Wed Jul 21, 2021 8:19 am
Thank you so much!
