It is currently Wed Jun 05, 2024 3:42 am
PostPosted: Thu Jun 14, 2018 8:50 am
I have a 14 turbo. On the head of the sail where the rope goes into the mast has worn through. Is there a good way to repair this or should it go to a sail repair shop?
84 14T Redline #67 Blue Hawaii faded but still working!
82 Yellow hull16 '81 Boomer nationals 20.9 on GPS
83 White hull 16 No sails "Clean and Purty Now!"
87 White hull no sails no tramp
PostPosted: Fri Jun 15, 2018 9:10 am
Can you provide a picture? It probably just needs a wrap of sail cloth over the damaged bolt rope cover. You could try a piece of self-adhesive sail repair tape. Otherwise use dacron sail fabric. You can bond it to the existing sail cloth using contact cement and/or stitch it on. If it is all the way at the very top of the sail, I would probably recommend removing the head plate from the sail, then put on the repair patch and re-install the head plate. That way the patch is sandwiched inside the plate.
PostPosted: Sun Jul 22, 2018 10:09 am
As a follow up,
I went to West Marine and bought their 3" wide x 15' long roll of self adhesive Dacron and a sail repair kit. I wrapped the Dacron around the bolt and sewed just along the rope and sewed across the ends of the tape to make sure it would stay down. I used it last night in ~ 5-10 knot winds and it held up great. The past attempts were with regular thread and I just sewed around the bolt. I had to re-sew the bolt every other sail outing so hopefully this will be a permanent fix for the rest of the season. The sail is definitely showing it's age and I will probably need a new sail for next year.
