It is currently Sat Apr 27, 2024 10:28 am
 Post subject: Stripped drain plug
PostPosted: Thu Apr 12, 2018 4:40 pm
Hello all I’m new to the forum. I have a 2007 getaway and apparently the previous owner stripped one of the drain holes. The plug stays in and is somewhat tight but leaks a bit and I’m curious if anyone knows a way to seal this or repair the actual drain hole?
 Post subject: Re: Stripped drain plug
PostPosted: Fri Apr 13, 2018 8:27 am
Try washing out the threads and use some silicone lubricant on the o-ring.
